are USDM 6 speed tranny's LSD ? (and are they the same final drive as jdm 6 speed ?)
Old Nov 27, 2003 | 07:18 PM
HotWheelz's Avatar
Default are USDM 6 speed tranny's LSD ? (and are they the same final drive as jdm 6 speed ?)
Old Nov 27, 2003 | 07:24 PM
VTECdTypS's Avatar
Default Re: are USDM 6 speed tranny's LSD ? (HotWheelz)
nope, niether
but u can get a type r lsd for under a grand
Old Nov 27, 2003 | 07:33 PM
HotWheelz's Avatar
Default Re: are USDM 6 speed tranny's LSD ? (VTECdTypS)
will it fit the case or the same "issue" with jdm tranny casings and usdm, where you can't put a jdm lsd inside an USDM case because the USDM case is smaller for the "non lsd" and wont' line up ?
Old Nov 27, 2003 | 08:25 PM
edo's Avatar
edo
some may have already discussed this in depth, but yes - the JDM LSD and final drive interchange perfectly. The FD swap requires changing to a smaller ID bearing for the 4.764 countershaft.
-Ron
Old Nov 27, 2003 | 09:08 PM
K20EG's Avatar
Default Re: (edo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edo &raquo;</TD></TR><TR><TD CLASS="quote">some may have already discussed this in depth, but yes - the JDM LSD and final drive interchange perfectly. The FD swap requires changing to a smaller ID bearing for the 4.764 countershaft.
-Ron</TD></TR></TABLE>
unless you get the Tsx final drive
4.760 Fd directly goes in
Old Nov 28, 2003 | 08:11 AM
edo's Avatar
edo
no, the TSX FD would require a "collar" to adapt the TSX countershaft to the RSX countershaft bearing.
If you do not get the "collar" - the countershaft will have too much play and will destroy the mainshaft.
-Ron
Modified by edo at 5:25 PM 11/28/2003
Old Nov 28, 2003 | 04:38 PM
K20EG's Avatar
Default Re: (edo)
interesting..w??
by chance do you have the part# for this collar TSx final in rsx-s tranny
thanks
Modified by K20EG at 4:39 AM 11/29/2003
Old Nov 28, 2003 | 07:01 PM
HaTcH_BmX's Avatar
Default Re: (K20EG)
is it possible to put an lsd into the 5 speed tranny?? (k20a3)
Old Nov 29, 2003 | 03:40 AM
K20EG's Avatar
Default Re: (HaTcH_BmX_Ep3 kid)
bump for edo to read my reply
Old Nov 29, 2003 | 10:20 AM
edo's Avatar
edo
saw it... I'll get it for you
The correct bearing for the TSX FD swap is:
91003-pps-003
Using this countershaft bearing eliminates the need for the collar, as it fits the TSX countershaft perfectly.
-Ron
Old Nov 29, 2003 | 10:24 AM
edo's Avatar
edo
yes, LSD fits 5-speed.
-Ron
Old Nov 29, 2003 | 12:41 PM
K20EG's Avatar
Default Re: (edo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edo &raquo;</TD></TR><TR><TD CLASS="quote">saw it... I'll get it for you
91003-pps-003
Thank ron
Old Nov 29, 2003 | 12:45 PM
K20EG's Avatar
Default Re: (K20EG)
shiot i got the last one ..the bearing is now on backorder
Old Nov 29, 2003 | 03:48 PM
keithg's Avatar
Application guide from http://www.quaifeamerica.com
Honda - 2002+ Civic Si 5-speed, Acura RSX 5-speed / RSX-S 6-speed, part no. 60.309.190.
$995.00 list price
And since I have a JDM LSD from http://www.jdmhondaparts.com in my USDM trans I assume that JDM and USDM use the same diff. (the quaife wasn't out yet when I bought it)
RACING INTEGRATION
Sep 21, 2005 05:54 PM
Suprdave
Feb 6, 2004 07:02 AM
mattcxb18
Feb 3, 2003 06:57 PM
acuracing
Jun 9, 2002 01:34 PM
