Walbro High Flow 255 lph fuel pump Q's
Old Nov 27, 2003 | 07:10 PM
Talon12bp's Avatar
Default Walbro High Flow 255 lph fuel pump Q's
Will i need a fuel pressure regulator?
I just bought a high flow 255 lph fuel pump, I have a t3t04 turbo going to be on a b18b pushin about 8 psi and using an fmu, any suggestions?
don't want anything to go wrong.
Thanks,
Bryan
Old Nov 27, 2003 | 07:39 PM
baphomet's Avatar
Default Re: Walbro High Flow 255 lph fuel pump Q's (Talon12bp)
not really, it will raise the fp 1-2 psi at the rail. Search, it has been covered.
Of course, some people say you need one because their pressure went really high, but what do I know. Install the pump and if you pressure is too high then put one in, you will just run a bit richer. As long as you idle fine, you do not need one - just install the pump first and see.
Old Nov 27, 2003 | 07:45 PM
Talon12bp's Avatar
Default Re: Walbro High Flow 255 lph fuel pump Q's (slashDEVslashNULL)
ok, ill do that,
thanks
Old Nov 27, 2003 | 07:49 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talon12bp &raquo;</TD></TR><TR><TD CLASS="quote">ok, ill do that,
thanks</TD></TR></TABLE>
no prob, let everyone know what happens.
Old Nov 27, 2003 | 11:25 PM
B18bEK's Avatar
i have a walbro 255 with a stock fuel pressure regulator and it works fine. i'm using hondata and not a fmu setup, but its on a b18b w/ 10psi - working great so far
Old Nov 28, 2003 | 04:12 AM
djnikko's Avatar
Default Re: (B18bEK)
I have a B&M fuel pressure regulator but I wanna fit a walbro 255 in the future, do i keep the B&M in there? or remove it? and search for a stock fuel pressure reg.?
any suggestions would be good
Old Nov 28, 2003 | 06:28 AM
b16ahybrid's Avatar
Default Re: (djnikko)
You can keep the B&M in there but it won't lower the fuel pressure if you need it to...
Old Nov 28, 2003 | 07:02 AM
Raunch's Avatar
Default Re:
What's the best fuel regulator out there for its price. I have an LS/Vtec turbo running 8 psi and need one.
Thanks,
Maurice
Old Nov 28, 2003 | 07:28 AM
igotyofire's Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">You can keep the B&M in there but it won't lower the fuel pressure if you need it to...</TD></TR></TABLE>
then how would u go about lowering it?
Old Nov 28, 2003 | 08:47 AM
baphomet's Avatar
Default Re: (igotyofire)
I have a b&m and I can set the pressure within spec (according to the helms).
Old Nov 28, 2003 | 09:10 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">
then how would u go about lowering it?</TD></TR></TABLE>
Get an actual fuel pressure regulator and not a fuel pressure riser like the B&M.
The B&M is just a riser. It can lower the fuel pressure about 10psi with a stock fuel pump, once you install i high flow/pressure pump it cant lower the fuel pressure because the output oraface is still stock and too small
Old Nov 28, 2003 | 09:15 AM
baphomet's Avatar
I forgot to mention I have a walbro 255 lph. But, I guess if for some reason you wanted to lower your pressure below stock you might be right - I haven't tried.
Modified by slashDEVslashNULL at 1:24 PM 11/28/2003
Old Nov 28, 2003 | 10:50 AM
Talon12bp's Avatar
Default will this work
so theoretically i will be fine as far as running lean not happening, if i don't get a regulator? just running the walbro 255 lph in place of the stock pump,
the turbo running @ 6 psi will work good for the stock injectors on the b18b?
Old Nov 28, 2003 | 11:33 AM
baphomet's Avatar
Default Re: will this work (Talon12bp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talon12bp &raquo;</TD></TR><TR><TD CLASS="quote">so theoretically i will be fine as far as running lean not happening, if i don't get a regulator? just running the walbro 255 lph in place of the stock pump,
the turbo running @ 6 psi will work good for the stock injectors on the b18b?</TD></TR></TABLE>
Old Nov 28, 2003 | 12:11 PM
b16ahybrid's Avatar
Default Re: (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to mention I have a walbo 255 lph. But, I guess if for some reason you wanted to lower your pressure below stock you might be right - I haven't tried.</TD></TR></TABLE>
no, generally when you run a high pressure fuel pump it raises your fuel pressure at idle so you would want to lower it back down to stock, not below stock....btw i have a 255lph holley hp....and my fp jumed to about 58psi at idle
Old Nov 28, 2003 | 12:23 PM
baphomet's Avatar
no, generally when you run a high pressure fuel pump it raises your fuel pressure at idle so you would want to lower it back down to stock, not below stock....btw i have a 255lph holley hp....and my fp jumed to about 58psi at idle</TD></TR></TABLE>
You don't understand what I said - the point was that I have stock pressure with the B&M and walbro 255lph HP. I have spoken to several people running stock fpr and they have only experienced a 1-2 psi increase in pressure at idle. I know that there is a slight difference in pressure between some of the oem reg. Maybe that accounts for your high pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
the stock FPR will be fine for 500-550whp range. I've measured with the walbro 255lph pump only changes 1-2 psi higher fuel pressure at the fuel rail.
Works for him, works for me.
Modified by slashDEVslashNULL at 3:47 PM 11/28/2003
Old Nov 28, 2003 | 02:29 PM
b16ahybrid's Avatar
Is your the high pressure or just the 255lph?
Old Nov 28, 2003 | 02:37 PM
booscivic's Avatar
I heard if you dril a hole in the fpr using a b&M you can lowerd the pressure is this true?
Old Nov 28, 2003 | 02:38 PM
b16ahybrid's Avatar
Default Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic &raquo;</TD></TR><TR><TD CLASS="quote">I heard if you dril a hole in the fpr using a b&M you can lowerd the pressure is this true?</TD></TR></TABLE>
yes
Old Nov 28, 2003 | 02:45 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Is your the high pressure or just the 255lph?</TD></TR></TABLE>
high pressure
Old Nov 28, 2003 | 03:00 PM
Talon12bp's Avatar
do i still need to use an fmu for now? or will the fuel pump alone work ok?
im going to be running 6 psi
Old Nov 28, 2003 | 03:01 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talon12bp &raquo;</TD></TR><TR><TD CLASS="quote">do i still need to use an fmu for now? or will the fuel pump alone work ok?
im going to be running 6 psi</TD></TR></TABLE>
If you do not have any other form of fuel management YES you need an fmu.
Old Dec 1, 2003 | 06:51 PM
phresh_5's Avatar
My stock fuel pressure was 32psi (D16Z6) and after the 255lph its at 40psi at idle
Old Dec 2, 2003 | 11:06 PM
SIK IN DA HED's Avatar
New User
there are never any consistent answers to these "will i need a fpr if i use a warlbro 255lph" questions. lol
Old Dec 2, 2003 | 11:07 PM
New User
Default Re: Walbro High Flow 255 lph fuel pump Q's (phresh_5)
there are never any consistent answers to these "will i need a fpr if i install a warlbro 255lph pump" questions. lol
