JUN H22 Valve Cover? Where can I buy one?
I was wondering if anyone knows where I can buy a JUN H22 valve cover?
It looks like this:
I didn't see any information about it in JUN's website. Any help is appreciated, thanks.
It looks like this:
it is most likely a valve cover painted yellow with a jun sticker on the spark plpug wire cover. make it yourself
i don't understand why people buy that kind of crap for ungodly prices when it can easily be duplicated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">why not just show the pic to a paint shop and have them paint one like it for you. All it is is a green to yellow fade, and some decal on the spark plug cover.</TD></TR></TABLE>
okay, didn't see the fade. yes, take it it to a paint shop to have it duplicated.
1 can of yellow heat-resistant spray enamel - $3.00
1 can of green heat-resistant spray enamel - $3.00
1 "JUN" valve cover - Priceless (or $6.00, depending on how you look at it
Andrew
)Andrew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety2SiR »</TD></TR><TR><TD CLASS="quote">Sorry, I didn't know how much it cost and I don't know how easily I could duplicate it. Just some high temp spray paint?</TD></TR></TABLE>
no need to apologize, just making an observation. anyway, yes a painted valve cover is easy. there is an extensive write-up if you search for it. but basically strip the old paint, primer and spray with the color of your choice. (hi-temp eng. paint is what i used) then sand the letters back down to metal. (don't use the chapstick method for the letters it is alot harder)
Personal observation if I may?
Unless you have a lot of JUN stuff... why would you want a fake JUN valve cover?
Isn't that the same as sticking a Type R sticker on your Prelude?
If you wanted to do it right, go to a powdercoating shop, and have them powdercoat the thing. However, unless you've got some JUN cams and valvetrain under that purty valvecover you're just going to get laughed at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx »</TD></TR><TR><TD CLASS="quote">If you wanted to do it right, go to a powdercoating shop, and have them powdercoat the thing. However, unless you've got some JUN cams and valvetrain under that purty valvecover you're just going to get laughed at. </TD></TR></TABLE>
i think it just about equates to the sticker theory. it won't give you 20hp. do it if they're your sponsor. or unless you have the full valvetrain and cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=449279</TD></TR></TABLE>
None of the pix work
