for suspension guru
Old Nov 27, 2003 | 03:40 PM
ggangtong81's Avatar
Default for suspension guru
do i need to get an alignment when i put the skunk2 sleeved coliover with agx?
one of my friend said no, and the other said yes. do i need it??
i am gonna drop it like an inch or 1.25.
Old Nov 27, 2003 | 03:49 PM
Mohudsolo's Avatar
Default Re: for suspension guru (ggangtong81)
Yes you do. When you change the ride height on a Honda you change the toe-in. When lowering both ends will toe out. That is the real cause of increased inside wear on lowered cars, not the extra camber. It will also make the car unstable.
Old Nov 27, 2003 | 04:51 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: for suspension guru (Mohudsolo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohudsolo &raquo;</TD></TR><TR><TD CLASS="quote">Yes you do. When you change the ride height on a Honda you change the toe-in. When lowering both ends will toe out. That is the real cause of increased inside wear on lowered cars, not the extra camber. It will also make the car unstable.</TD></TR></TABLE>
Yes you will.
Suzukii
16
May 18, 2008 01:58 PM
.water
Suspension & Brakes
11
Oct 23, 2005 08:24 AM
peel17
Sep 1, 2005 08:00 AM
brg2nr
Suspension & Brakes
Jan 27, 2005 10:55 PM
R_Machine
Sep 23, 2003 12:27 PM
