5W-20 in my B18C5?
Old Nov 27, 2003 | 12:52 PM
Enrikez's Avatar
Default whats with this 5w-20? OK in a B18c5?
i went to the hOnda for an oil change which i always do. i have pretty much a brand new motor b18c5 with about 3000 miles on it in a 00 civic si. Anyway, they ended up putting in Hondas new 5w-20 in my motor. they insisted that it would be fine, and that its very close to 5w-30 and that it would decrease emissions and fuel consumption. my motor has a fully built Toda B head. will there be any problems or should i just switch back to 5w-30. i dont rev the **** out of it but i want to be safe. i'm in south Texas right now where it has been getting pretty cold lately. will this oil be OK. Its made by Exxon to Hondas specs...thats what it says on the quart anyway. (just a little paranoid)!!!
thanks
Old Nov 27, 2003 | 02:28 PM
jetydosa's Avatar
25 Year Member
Default Re: whats with this 5w-20? OK in a B18c5? (1meanB18c5civic)
I am surprised they would do that. If it was me Id either change it back to 5w30 myself or take it back and make them do it. Honda only recommends the 5w20 in 02+ models.
Old Nov 27, 2003 | 02:42 PM
Dirt's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (Jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">I am surprised they would do that. If it was me Id either change it back to 5w30 myself or take it back and make them do it. Honda only recommends the 5w20 in 02+ models.</TD></TR></TABLE>
I'd do the same. 5w20 may seriously thin out after 3000 miles.
Old Nov 27, 2003 | 02:44 PM
SleepnCiViC's Avatar
that 5w20 oil is made for most 2001+ hondas and fords. But on all 5w20 application it will say that on the oil cap if its required. Anyway if you decide to switch to synthtic, mobile1 one offers a systhetic version but its called 0w20 not 5w20. ment speciffically for those fords and hondas
Old Nov 27, 2003 | 02:45 PM
len's Avatar
len
We stick 5w20 Oil in every car that comes through our dealership and tells the customer to go F themselves. J/K
Yah, if you're concerned with it, take it back and make them change it. At most dealerships Oil Changes are at cost and designed so that they can make upsales on them. Like, brake jobs and what not.
Old Nov 27, 2003 | 04:04 PM
jond's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (len)
Many people think 30 weight is too thin, much less 20 weight. I wouldn't use it. Our engines rev way too high for a 20 weight to work well. 5w30 or 10w30 is the only thing you should put in a b18c5 IMO.
Old Nov 27, 2003 | 04:19 PM
JjuuN R's Avatar
what jond said
Old Nov 27, 2003 | 04:52 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1meanB18c5civic &raquo;</TD></TR><TR><TD CLASS="quote">i went to the hOnda for an oil change which i always do. i have pretty much a brand new motor b18c5 with about 3000 miles on it in a 00 civic si. Anyway, they ended up putting in Hondas new 5w-20 in my motor. they insisted that it would be fine, and that its very close to 5w-30 and that it would decrease emissions and fuel consumption. my motor has a fully built Toda B head. will there be any problems or should i just switch back to 5w-30. i dont rev the **** out of it but i want to be safe. i'm in south Texas right now where it has been getting pretty cold lately. will this oil be OK. Its made by Exxon to Hondas specs...thats what it says on the quart anyway. (just a little paranoid)!!!
thanks </TD></TR></TABLE>
i'd suggest no lower than 5w30.
Old Nov 27, 2003 | 08:07 PM
mickey513's Avatar
If you look in a bottle of 5w-20, there is a warning label that clearly states do not use unless this is the weight recommended by the car maker.
Old Nov 28, 2003 | 05:50 PM
Enrikez's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (mickey513)
well i decided to just change my oil in the morning. went with someones suggestion of using Castrol GTX 5w-30 . Better safe than sorry i guess .
Old Nov 28, 2003 | 05:56 PM
ZygSpeed's Avatar
Reminds me .. I need to change my oil too!
As well as my MTL.
Frankly, Honda probably doesn't have any other weight oil on their premesis!
Old Nov 28, 2003 | 06:02 PM
Bbasso's Avatar
All you need to do is show them this:
https://honda-tech.com/zerothread?id=681653
Modified by Bbasso at 10:18 PM 11/28/2003
Old Nov 28, 2003 | 06:15 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Honda only recommends the 5w20 in 02+ models.</TD></TR></TABLE>
That's not true. In the owners manual for my '02 RSX Type S, it specifically says to use 5w-30. But for the base model RSX, it says it can use either a 5W-20 or 5w-30.
Old Nov 28, 2003 | 10:40 PM
bcrl's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (sjracer)
How about 0w-30?
Old Nov 29, 2003 | 04:47 AM
jetydosa's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjracer &raquo;</TD></TR><TR><TD CLASS="quote">
That's not true. In the owners manual for my '02 RSX Type S, it specifically says to use 5w-30. But for the base model RSX, it says it can use either a 5W-20 or 5w-30.</TD></TR></TABLE>
Isnt that a 02+ model?
Is there a 2001 or older that requires 5w20? (Insight maybe I guess?)
Old Nov 29, 2003 | 06:08 AM
Agent#ONE's Avatar
ive used 5/20 in my c5, raced on it as well, no problems here, ofcourse i change it every 1000 miles along with the plugs after every track event
Old Nov 29, 2003 | 06:15 AM
DCStreetHtch's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (Agent#ONE)
the problems that may arise from running the 5w-20 would definitely only arise after a good 3000+ hard miles. I'd still take it back and tell them you're not satisfied after all!
-Bryan-
Old Nov 29, 2003 | 06:46 AM
Suprdave's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (EGStreetHtch)
Depends on Bearing Clearances and Temperature.
Average Joe should just use 5w30 Castrol.
Suprdave
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent#ONE &raquo;</TD></TR><TR><TD CLASS="quote">ive used 5/20 in my c5, raced on it as well, no problems here, ofcourse i change it every 1000 miles along with the plugs after every track event</TD></TR></TABLE>
Do you take oil samples, or have you been racing with this 5W20 for 100,000 miles? Otherwise, how do you know you're not doing damage?
Old Nov 29, 2003 | 07:16 AM
Enrikez's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (jond)
nah man for real, when i pulled that oil its like ******* water. i can see why it couldnt be used in an rsx Type s eithier. the high revs will burn it right up. if i was too use it. i would definetely always be checking my oil and probably change it every 1500 miles on my C5 depending on how hard i drove it.
yeah, it spins nicer...but reliabilty is an issue with me.
LIKE WATER!!!!!
tip of the day....be smart. use 5w-30.(at least)
Old Nov 29, 2003 | 07:35 AM
Jason's Avatar
5-30 is the way to go
Old Nov 29, 2003 | 09:15 AM
Agent#ONE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
I dont take oil samples, but i do race, and i change oil before and after i race, or every 1000 miles, its only a few bux to change your oil/filter.
as for doing damage to my motor, i believe im doing fine since i do my own work, ive taken the motor apart several times to inspect it.
along with the good ol' spoon magneto drain plugs that help identify if your having an oiling problem, im doing just fine.
i do believe that if you abuse this oil and do not change it when you should, that indeed it will wear thin, and not do its job properly.
ive had this in mind the whole time, which is why i change the fluids in my car so often.
but i think the rumor is true...ITR motors get better with age.
Old Nov 29, 2003 | 01:49 PM
ejprimo's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">All you need to do is show them this:
but what if your ITR manual looked like this:
Old Nov 29, 2003 | 03:28 PM
itr 00 0108's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (ejprimo)
Does anyone know what those numbers actually mean or are you just pulling info out of your ***?
Old Nov 30, 2003 | 12:42 AM
MiraiZ's Avatar
Default Re: whats with this 5w-20? OK in a B18c5? (itr 00 0108)
If its a new motor, I don't think it'll be a probelm, but as you put miles in, I would get some higher viscosity or your car will burn oil like a bitch
