Knock sensor for JDM B16a gen 1?
Old Nov 27, 2003 | 11:14 AM
littlecrxVTEC's Avatar
Default Knock sensor for JDM B16a gen 1?
I am missing my knock sensor on my jdm b16a gen 1 (obd-0) and i was wondering which USDM knock sensor i need to use??? For instance- ive found one from a 97 integra gsr (obd-1)...is this the right spec. and will it plug up? Thanks, any input would be great.
_TIM
Old Nov 27, 2003 | 04:42 PM
VTECVillain's Avatar
Default Re: Knock sensor for JDM B16a gen 1? (timcrxsi)
Any knock sensor will work from the B series or even the 96+ EX. The OBD style doesn't matter, they are the same.
Old Dec 1, 2003 | 08:15 AM
VWkila's Avatar
Default Re: Knock sensor for JDM B16a gen 1? (VTECVillain)
This the first gen. B16a have a knock sensor?
Old Dec 1, 2003 | 09:34 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Knock sensor for JDM B16a gen 1? (VWkila)
Yep, VTEC would not engage on my friends JDM B16A without it plugged up.
Old Dec 1, 2003 | 12:37 PM
eyeamvic's Avatar
Or you can always do the chipped p28 which doesn't have a knock sensor.
Old Dec 19, 2003 | 09:50 PM
89sib16's Avatar
where is the knock sensor located on this motor. I can only find two sensor's .. Thaey are above the oil filter a 2 wire sensor and a 1 wire sensor,..Maybe it is missing from the motor im not sure .
Old Dec 20, 2003 | 03:41 PM
Devlins 91LS's Avatar
Default Re: Knock sensor for JDM B16a gen 1? (89sib16)
Its a green plug stickin out above the two sensors by the oil filter, its RIGHT up underneath the IM runner for the #3 cylinder
Mad-Mike
Jan 18, 2011 01:45 PM
blk crx
Mar 13, 2007 01:17 PM
meagainsttheworld
Aug 25, 2006 01:08 PM
ek_b16
Jan 4, 2005 10:41 PM
