Help me Choose the right Sc61
Old Nov 27, 2003 | 10:25 AM
Boostage's Avatar
Default Help me Choose the right Sc61
my motor is a b16. the Compression ratio is 8.8:1 that is very low in a b16 redline will ultimately be 9500 rpms Im leaning towards the .63 a/r But I am worried about only having top end and no midrange and low end. I want when I step on my gas the car goes not waiting for boost to hit. what do you think of this. sc61 "e" housing .63 a/r ?? btw I have AEM ems
Old Nov 27, 2003 | 11:02 AM
alpha's Avatar
Default Re: Help me Choose the right Sc61 (Ateyour2JZ)
If you want low end you should of went with a higher compression ratio. I have yet to see someone use a .48 A/R turbine housing. Honestly I would like to see a .48 A/R SC61 dyno sheet. Even with an 8.8:1 compression ratio and a 9500 rev limit you shouldn't have problems making power and pulling good times with the .63 A/R turbine housing.
Old Nov 27, 2003 | 11:12 AM
AlphaKennyWun's Avatar
There is tons of info on this if you search. There is no low end on a sc61 and a stock bore. The mid range and especially top end are excellent though. If you go with a .48 you may get a 400 rpm quicker spool but your top end will suffer considerably
Everyone who rides in my car (B18c SC61 9:1 comp) is like The power is all above 5000 rpm though, but im real happy with it. I know how to drive my car and passengers can't tell its laggy. I also have my low end tuned for all the power i need there, its not slow.
If you want low end look into a smaller turbo. i had a t3/t4b .63 and it would spool around 2500-3000 rpm but its not as fun as my sc61. When i built my motor i switched to the sc61 and im glad i did. The t3/t4b is more like a beginner turbo but it could still make 400 hp.
Old Nov 28, 2003 | 07:39 AM
Boostage's Avatar
Default Re: Help me Choose the right Sc61 (S03Burner)
It may take 5000 rpms to hit 10-12psi but the car will pull really hard while building up boost right?
Old Nov 28, 2003 | 08:02 AM
FredoSP's Avatar
there were some SC61 dynos posted not too long ago, hit up the search button
Cause Im nice ...
https://honda-tech.com/zerothread?id=654448
Old Nov 28, 2003 | 09:30 AM
11psiTurboSI's Avatar
Default Re: Help me Choose the right Sc61 (FredoSP)
Just to give you a idea i have a b16a2 with 8.8:1cr with a SC50 .63ar and it spools slow as hell
Old Nov 28, 2003 | 10:01 AM
Muckman's Avatar
Moderator in Chief
low end is over rated. it just results in wheel spin in our cars.
Old Nov 28, 2003 | 10:50 AM
M.A.R.C.'s Avatar
Default Re: Help me Choose the right Sc61 (9psiTurboSI)
i spoke to rod @ precision the other day and he said they don't offer the sc61 in .48 a/r turbines anymore and only in T350 (stage 5) wheel.
Old Nov 28, 2003 | 12:04 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S03Burner &raquo;</TD></TR><TR><TD CLASS="quote">
WTF? if you have a SC61 .63 or larger, you dont have low end, period.
muckman is correct though, lowend=wheelspin
Old Nov 28, 2003 | 01:18 PM
Default Re: Help me Choose the right Sc61 (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
As stated above I wrote "I have my low end tuned for all the power i need." I never said i was boosting in low end. Its pretty elementary that a tuner can lean out a car and optimize hp even before boost comes on. To some extent my car runs better off boost than when it was totally n/a. All i meant by what I said to the original poster was that you can have a laggy turbo but by no means does your car have to be a rich running slow pig when not in boost. Maybe he wont be happy not boosting in low end but thats for him to decide. As i said before i have all the power i need down low when not in boost.
Old Nov 28, 2003 | 01:25 PM
M.A.R.C.'s Avatar
As stated above I wrote "I have my low end tuned for all the power i need." I never said i was boosting in low end. Its pretty elementary that a tuner can lean out a car and optimize hp even before boost comes on. To some extent my car runs better off boost than when it was totally n/a. All i meant by what I said to the original poster was that you can have a laggy turbo but by no means does your car have to be a rich running slow pig when not in boost. Maybe he wont be happy not boosting in low end but thats for him to decide. As i said before i have all the power i need down low when not in boost. </TD></TR></TABLE>
yah i know what ur saying. my friend has a turbo tercel with the 1.3L turbo starlet motor and he has a t3/t04e 57 trim on it. kinda laggy but it still doesn't feel like a pig off boost. in fact i was talking to him about having a laggy turbo (sc61 on 1.7L d16) and he said his tuner tuned his car to be "peppy" off boost. makes sense.
Old Nov 28, 2003 | 02:08 PM
Default Re: Help me Choose the right Sc61 (CivicRyda2k)
Thanks civicryda and starlets are badass cars
Modified by S03Burner at 6:21 PM 11/28/2003
Old Nov 28, 2003 | 02:29 PM
Mase's Avatar
sorry but your response makes no sense. its funny that you went to the extent to say "its pretty elementary that a tuner can lean out a car and optimize HP even before boost comes on...." you're way off -
a "properly" tuned motor before boost, would be a car that runs slightly rich w/ a bit of timing retard, this helps the turbo spool. Dont try to argue that either, ive proved it to be true w/ datalogs.
I dont know what kind of 'tune' youd call it, but its not optimal. (trying not to sound like a dick here)
Racersky
Nov 9, 2005 07:42 PM
Boostage
Jan 19, 2005 03:22 PM
SpoonfedDC2
Dec 8, 2002 08:55 AM
