Need b16a help asap
Old Sep 15, 2001 | 09:33 AM
4G-CIVIC's Avatar
New User
Default Need b16a help asap
OK, I am wiring a b16a into a civic dx. I am using a 90 SI wiring harness on the SIR motor, should I be using the DX wiring harness on the SIR motor and converting the fuel system part over? I heard that was easier to do? The wiring is done for the most part but I need some tech references to check with on a few things. Also, the distributor is getting power but not throwing any power to the wires or plugs.
If anyone know of some websites to check with let me know. Obviously I have checked:
HYbid.honda-perf.org
tiiite.b16a.com
... are there any other good ones out there?
Your help is much appreciated.
Old Sep 15, 2001 | 11:59 AM
Red Civic T's Avatar
New User
Default Re: Need b16a help asap (4G-CIVIC)
umm, what about HASport site http://www.hasport.com?
Old Sep 15, 2001 | 04:19 PM
BIG RICH's Avatar
also http://b16a.honda-perf.org
Old Sep 15, 2001 | 06:28 PM
rioninja's Avatar
My buddy had the same exact problem. There is a small ground wire that goes to the thermostat housing. Without this wire grounded, the distributor wont fire.
Old Sep 16, 2001 | 12:53 PM
4G-CIVIC's Avatar
New User
Thanks for the help guys. Rio Ninja: what you said makes sense, I will definately try that.
I also found out that the cylinder position wires have to be rewired.
carlosjdmcivic
Mar 23, 2010 07:24 PM
myorangecar
Jan 12, 2005 01:08 PM
EF-21
Mar 12, 2004 10:35 PM
SC0TT
May 13, 2002 04:04 AM
