squeakng noise from wheel
Old Nov 27, 2003 | 08:07 AM
alb_accord's Avatar
Default squeakng noise from wheel
what's up guys. i have a 90 accord ex and i am hearing squeaking noise from the right wheel. it does the squeaking noise when it goes on small bumps and when i turn the steerking wheel to the right but it does not do the noise when i turn left. now i pushed the car down from the top and i think the noise comes from the middle of the wheel. i have been told from the accord forum it might be the shack but why does it do the noise more when i turn the steerign wheel to the left. if u guys know what it is i would appriciate if u tell me what is wrong with my car
thank u
Old Nov 27, 2003 | 06:03 PM
f22a's Avatar
Default Re: squeakng noise from wheel (alb_accord)
sounds like it could be coming from the sway bar bushings, check to see if they are there/in good condition.
are you running any polyurethane bushings on the car?
Old Nov 28, 2003 | 06:34 PM
alb_accord's Avatar
sorry man i don't know what bar bushigs is but i checked the rubber thing that holds the wheel and it looks fine. what ever is in the wheel is stock. i haven't done any upgrades. one thing if it helps is that when i jack up the car to check what is wrong. the noise desepears for like 24 hours then comes again. now it is doing all the times don't matter if i jack up the car it's still going to do it. i hope it help dertemine what is wrong with my car thanks for the reply
Old Nov 28, 2003 | 10:54 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alb_accord &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 accord ex and i am hearing squeaking noise from the right wheel. it does the squeaking noise when it goes on small bumps and when i turn the steerking wheel to the right but it does not do the noise when i turn left. </TD></TR></TABLE>
Does it make the noise turning the wheel with the car sitting still?
Old Nov 29, 2003 | 08:40 AM
The_Todd's Avatar
Farts in the shower
Default Re: squeakng noise from wheel (Chiovnidca)
I have this same problem sort of......its a high pitched whine only when I turn the wheel and only in certain spots its not my cv's i had those replaced (the clicking) and I took it to my mechanic he sprayed some wd-40 on it, it went away for like 2 weeks and is now back. I was thinking wheel bearing (but those are usually noticable when driving) any suggestions would help. thanks
Old Nov 30, 2003 | 01:36 PM
alb_accord's Avatar
hey chiovnidca it does it both man. either when i turn the wheel with the car and when i turn the wheel standing still man. it does it all the times. both times.
do u have any idea what is wrong with it man?
Old Nov 30, 2003 | 01:39 PM
Chiovnidca's Avatar
Default Re: (alb_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alb_accord &raquo;</TD></TR><TR><TD CLASS="quote">hey chiovnidca it does it both man. either when i turn the wheel with the car and when i turn the wheel standing still man. it does it all the times. both times.
do u have any idea what is wrong with it man?</TD></TR></TABLE>
Probably a bad lower ball joint. Pull back the boot to see if it is rusty inside.
Mr.Luder
Oct 16, 2007 03:54 PM
Baron55
Apr 7, 2006 08:30 AM
poisonko
Jan 15, 2006 12:30 PM
Sephro
Oct 11, 2002 10:34 AM
2005 TSX
Apr 4, 2002 11:34 AM
