91 dx sedan motor swap to 88 crx hf
does anyone know if the computers in the 91 dx and the 88 hf are identical? im throwing the motor from the dx into the hf and need to know if theres anything different on the two that i need to worry about... im also using the 91 tranny in the hf. also, are axles and suspension components the same on teh two cars? thanks,
nick
nick
the ecus are very different, the HF runs MPFI and the DX runs DPFI, you need to do the MPFI swap it you want to run the HF ecu
