ICV craziness with OBDII ecu
Hi,
Whenever I have my Stock 2001 OBDII ECU in the car, my R drives great, however it seems like once in a while, it goes into "crazy idle" and the CEL comes on... I'm not too sure what really triggers it as sometimes I go for long stretches (days, a week) without incident and just when I think I've beat it, it comes back to haunt me once again.
When it comes back, it seems like even after CEL reset, it will come back shortly (in a day or less). I'm not sure if it is the weather or what... I've checked the O2 sensor in the cat, but I didn't think it was that anyway, but I was "down" there and decided to take a look regardless.
With the code reader I get two P0505's, after the first one, nothing happens, but the second one triggers the CEL and the crazy idle...
when I say crazy, it's not _that_ bad per se, its driveable but annoying... especially at low speeds (i.e. parking lot). It hangs at about 1500-1600 rpm and flucuates a bit, like it's balancing but sounds like "lumpy idle" or like I'm continually tapping the gas slightly (but I'm not)... and when I'm driving in parking lots I have to control the throttle alot more carefully as it seems to come on a little rougher/harder...
It seems to egg on most ricers that pull up beside me at the lights, not that I mind reminding them that it is an R... but still...
I have an AEM CAI and a larger TB, but I'd figure that the ICV and ECU wouldn't have a hard time with that and would adjust accordingly...
I don't think there is anything wrong with the ICV... but, who knows...
Using my other "tuned" ECU, this problem never comes up... but I do want to drive with the stock ECU sometimes, sigh... it's a pain to reset the CEL unless I carry my code reader all the time, but that's ghetto
and I don't want to pull the clock fuse all together either...
What do ya think guys?
.I have an AEM CAI and a larger TB, but I'd figure that the ICV and ECU wouldn't have a hard time with that and would adjust accordingly...
and I don't want to pull the clock fuse all together either...What do ya think guys?
Boy this board moves fast...
I also have a lightened flywheel... If that helps...
And ICV = Idle Control Valve... if anyone has heard or experienced this... please let me know I'm not the only one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2fanboy »</TD></TR><TR><TD CLASS="quote">I have an AEM CAI and a larger TB, but I'd figure that the ICV and ECU wouldn't have a hard time with that and would adjust accordingly...
Off hand, I'd say your ECU needs some re-tuning to deal with the larger TB, or at least some notable adjustment of the idle specs.
</TD></TR></TABLE>Off hand, I'd say your ECU needs some re-tuning to deal with the larger TB, or at least some notable adjustment of the idle specs.
You have a code reader? Can you look at all of the sensors with the engine running or with key on, not running ? Your TPS should be at 0.49 volts throttle closed, and about 4.5 volts at WOT.
red_EF9Si
Sep 19, 2005 01:24 PM
