ITR Sway HELP!!!
Old Nov 26, 2003 | 11:36 PM
WalkmanX's Avatar
Default ITR Sway HELP!!!
A couple buddies and I got together to install my ITR sway bar tonight and everything went smoothly until that welded nut. We kept hitting both with a hammer but they wouldn't budge. We eventually got one of the bolts off but we decided maybe the other will come off if we drill thru it (worst idea ever!!!)
After we drillled thru it the bolt still wouldn't move so we decided to chisel it(with flat head screw driver) but that didn't work either so we started to dremel it. Now the nut is all messed up/deformed and I had to call it a night cuz it was getting really late.
What do you guys suggest I should do? Should I get an air chisel and take it off? Should I get more dremel bits and dremel it off?
Or should I take it to a shop? I so regret drilling the hole thru the nut and not following the directions more closely
Old Nov 27, 2003 | 12:16 AM
oMek's Avatar
Default Re: ITR Sway HELP!!! (WalkmanX)
on my 95 gsr its was very easy. one of them i put bolt 1/2 way back in and smacked it with a hammer really good and it fell off. the other 1 would not come off with the hammer so i got a wood chisel with a sharp edge and it came off quick.
Old Nov 27, 2003 | 12:27 AM
Al Bundy's Avatar
get a wrench and put a long tube over it. Turn the wrench and it should fall off.
Old Nov 27, 2003 | 12:34 AM
SMZ GSR's Avatar
Default Re: ITR Sway HELP!!! (oMekoneDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">on my 95 gsr its was very easy. one of them i put bolt 1/2 way back in and smacked it with a hammer really good and it fell off. </TD></TR></TABLE>
did the same thing for both nuts on my gsr.
Old Nov 27, 2003 | 10:24 AM
WalkmanX's Avatar
Default Re: ITR Sway HELP!!! (Al Bundy)
that's a great idea but I need to buy one of those multi-socket-in-one things to get it to fit my deformed bolt I'm not even confident if I can dremel it off w/o damaging the subframe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al Bundy &raquo;</TD></TR><TR><TD CLASS="quote">get a wrench and put a long tube over it. Turn the wrench and it should fall off.</TD></TR></TABLE>
spideymangDC4
Suspension & Brakes
Jan 10, 2008 12:07 AM
mrdeadman
Feb 11, 2006 04:53 PM
beanbag
Jan 20, 2006 09:05 AM
AlxSiR7
Dec 11, 2004 02:26 PM
mixmastabob
Jan 6, 2004 09:51 PM
