d15b distributor problems
Old Nov 26, 2003 | 10:07 PM
skrappy's Avatar
Default d15b distributor problems
i did my own wirreing but i got code 4 crank angle sensor is i chane my distributor will i get rid of that code
Old Nov 27, 2003 | 07:51 AM
onePOINTsix's Avatar
Default Re: d15b distributor problems (skrappy)
im taking it you did a mpfi swap, 2 of the wires you cut are for the crank angle sensor, it's not in the dizzy, i had the same problem and i searched areoud for the wiring diagrams for my car and found that 2 of the wires you cut actuall need to be reconnected. as for the diagrams i cant help you now, i'll try to find them later
edit:dizzy has a cyl. position sensor, thte block has a crank angle sensor (this is to clear up confusion)
Old Nov 27, 2003 | 07:59 AM
Big Bang's Avatar
again assuming a MPFI swap, Did you use shielded wires?? I dind't at first and always had a CEL, re ran shielded when doing the motor swap and everythign went away so i'd start there.
Old Nov 28, 2003 | 06:59 AM
jlicrx's Avatar
Default Re: d15b distributor problems (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">im taking it you did a mpfi swap, 2 of the wires you cut are for the crank angle sensor, it's not in the dizzy, i had the same problem and i searched areoud for the wiring diagrams for my car and found that 2 of the wires you cut actuall need to be reconnected. as for the diagrams i cant help you now, i'll try to find them later
edit:dizzy has a cyl. position sensor, thte block has a crank angle sensor (this is to clear up confusion)</TD></TR></TABLE>
code 4 = crank angle sensor, which is in the distributor
code 9 = cylinder position sensor, which is also in the distributor for SOHC MPFI engines - for DOHC ZC engine, it is on the end of the exhaust camshaft
for DPFI to MPFI swap the crank angle sensor wires are not changed - if you are getting code 4, you either have a bad distributor or your camshaft timing is not correct
Old Nov 28, 2003 | 09:02 AM
skrappy's Avatar
Default Re: d15b distributor problems (jlicrx)
ok im going to replace my dizzy thanks
Nathan_volcom
Oct 21, 2011 05:49 AM
drinks2k
May 10, 2007 10:15 PM
mugenhatch92
Aug 31, 2004 10:09 AM
streetdreams420
10
Aug 13, 2003 02:15 PM
89 CRX SI
27
Jan 20, 2003 04:12 PM
