help with wiring on an alpine deck, in eg civic
Old Nov 26, 2003 | 02:49 PM
Tad's Avatar
Tad
Default help with wiring on an alpine deck, in eg civic
Ok, so I got a new alpine cdm 9803,
i know what todo with all the wires, except one.
it says its the battery wire,
and should hook up to one ofthe terminals on my battery.
its yellow and has a fuse hooked onto it.
NOW, there is a separate wire for the 12v power,
do I still need to hook up this battery wire?
I ask because I'd really rather not have to find a way thru the firewall to get
to the battery.
I've got extra long wires lying around i can use,
but I really dont want to have to go all the way out there.
any input would be great!
thanks!
Old Nov 26, 2003 | 05:59 PM
brads94accord's Avatar
Default Re: help with wiring on an alpine deck, in eg civic (Tad)
just connect the the battery wire to the 12 volt battery wire. you don't have to run a wire to the battery.
Old Nov 26, 2003 | 06:52 PM
92civicsi's Avatar
Default Re: help with wiring on an alpine deck, in eg civic (brads94accord)
yeah just take a multimeter or test light and find the power wire. the one that puts out power when your key is off. and red goes to the acc wire. the one that turns on when u turn ur key. black goes to ground.
http://www.installdr.com
Old Nov 26, 2003 | 07:09 PM
Eric R's Avatar
Default Re: help with wiring on an alpine deck, in eg civic (92civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicsi &raquo;</TD></TR><TR><TD CLASS="quote">yeah just take a multimeter or test light and find the power wire. the one that puts out power when your key is off. and red goes to the acc wire. the one that turns on when u turn ur key. black goes to ground.
Ditto.
Old Nov 26, 2003 | 10:55 PM
salbaje's Avatar
wire it up to constant 12v power to your fuse box there are open slots there
Old Nov 28, 2003 | 01:35 PM
Tad's Avatar
Tad
thanks for all the replys guys
brads94accord hit it right on the head,
there WAS a battery wire already there, separate from the 12v iginition wire,
I wired it up to the battery wire and it works great!!
thanks
Old Nov 28, 2003 | 04:50 PM
vtec_yosh's Avatar
On the CDA9807 and below, it is fine on hooking them up to the constant wire in the harness, but I highly reccommend going straight to the battery on any of the higher models. With the CDA9811 and up, they seem to draw more power and tend to fade out during scrolling until they have their own dedicated wire ran to the battery. Just my $.02!!
Old Nov 28, 2003 | 06:47 PM
Tad's Avatar
Tad
Default Re: help with wiring on an alpine deck, in eg civic (vtec_yosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_yosh &raquo;</TD></TR><TR><TD CLASS="quote">On the CDA9807 and below, it is fine on hooking them up to the constant wire in the harness, but I highly reccommend going straight to the battery on any of the higher models. With the CDA9811 and up, they seem to draw more power and tend to fade out during scrolling until they have their own dedicated wire ran to the battery. Just my $.02!!</TD></TR></TABLE>
roger!!
Old Nov 28, 2003 | 08:36 PM
rcurley55's Avatar
New User
This is only going to be the case if you are using the internal amplifier --- at least it should be
Old Nov 29, 2003 | 12:10 AM
Tad's Avatar
Tad
Default Re: help with wiring on an alpine deck, in eg civic (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">
This is only going to be the case if you are using the internal amplifier --- at least it should be</TD></TR></TABLE>
if I have no other amp, then am I using the internal amplifier?
or do I have to activate it or somethin?? (audio noob here, hehe)
f22a1 ftw
Dec 8, 2009 08:06 PM
91EF919
Apr 6, 2009 08:27 PM
ZOMBIEKILLER
Audio / Security / Video
Feb 24, 2008 07:14 PM
4runner
Jun 9, 2005 11:38 PM
jonoknut
Sep 19, 2002 03:17 PM
