fuel line/hose with banjo bolt question...
i had an in-line fuel pump which was installed on the banjo bolt fuel line. i am now removing it and need a new hose.
can i just replace the hose and reconnect the used banjo fittings?
-or-
are the fittings fused onto the hose and will need to be replaced entirely? btw, they're $75 for the whole set so i would like to be able to do choice A
thanks!
-ray
-or-
thanks!
-ray
in order for you to re-use the banjo fitting on your line, the new hose will need to be crimped into the banjo hose end. The stock banjo line are non-reusable, therefore you need to buy a whole new hose assembly
stan
stan
