Is this the correct gasket?
98 GSR in 95 EG, im leaking oil from valve cover on the left hand bottem corner...should i get the whole gasket set or just the one piece? also anyone selling their spark plug wire cover?
http://www.acuraautomotivepart...y.jsp
For a 98 GSR you would need part #5 on the right diagram (main cover gasket) and it can't hurt to change #7 also (there are 4 of these #7's) they are the spark plug gaskets, may not be needed but not a bad idea. i doubt you would need any of #23 for you situation. hope that helps.
-Mike
-Mike
Get the #1 on the right.
I usually just replace the entire set if I'm gonna replace it at all. Sometimes it gets pretty hard after so much heat cycling.
The #23 washers get pretty gnarly after so many installations/removals that they catch threads coming off the studs, making it harder to remove them and easier to lose.
denierlexiese
Aug 17, 2015 07:03 AM
finish the job right
