Few quick Skunk manifold questions...
Old Nov 26, 2003 | 05:55 AM
Mark's Avatar
*Bounty Hunter*
Default Few quick Skunk manifold questions...
Ive read the write up's etc, I just have a few small questions...
When its read to tee up vacuum lines, would a plastic piece do (even temporarily?) I bought em from Autozone...
What is the size of the hose I need to run from the top middle of the skunk mani., to the tee with vacuum lines?
I also have a spare coolant line underneath the VTEC solenoid that I dont think I need, what should i do with it? A friend said to block it up somehow, maybe with a nipple or something (Im assuming there isnt going to be any pressure going that way...)
And finally, what is the blasted size of the bolts to the fuel rail? I bought m10x1.25x10mm and they were too thick!
Thanks guys :D After all this I can finally drive my car again !
Old Nov 26, 2003 | 06:24 AM
IN VTEC's Avatar
Default Re: Few quick Skunk manifold questions... (Mark's Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark's Integra &raquo;</TD></TR><TR><TD CLASS="quote">
What is the size of the hose I need to run from the top middle of the skunk mani., to the tee with vacuum lines?</TD></TR></TABLE>
I never had to tee any of the vacuum lines. The FPR goes to the front of the manifold above the #1 runner. The EVAP solenoid goes to the small nipple on the back on the #1 runner side. The PCV goes to the 9mm nipple (3/8" hose) in the front middle. All of the hoses are separate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I also have a spare coolant line underneath the VTEC solenoid that I dont think I need, what should i do with it? A friend said to block it up somehow, maybe with a nipple or something (Im assuming there isnt going to be any pressure going that way...)</TD></TR></TABLE>
That one normally goes to either the thermostat housing or the throttle body/FITV. It just depends on how the cooling lines are arranged on your year of B18C1. The newer motors have simplified routing.
And finally, what is the blasted size of the bolts to the fuel rail? I bought m10x1.25x10mm and they were too thick!</TD></TR></TABLE>
Use M6x1.00x31mm studs. See official Skunk2 IM post created by Bolivian-somethingorother.
j-wow
Jul 20, 2011 02:44 PM
2000__GSR
Jul 21, 2010 06:52 AM
sp00led
Aug 20, 2008 09:38 AM
Tactic$
May 2, 2005 12:03 PM
integra-modder
Nov 13, 2003 11:41 PM
