Wiring separate power door lock selenoids to work with OEM power doorlocks
Old Nov 26, 2003 | 03:46 AM
Jay J's Avatar
Prince of Zamunda
Default Wiring separate power door lock selenoids to work with OEM power doorlocks
I was wondering if it'd be possible to install separate metal bar power door lock selenoids on an integra with OEM power doorlocks to open with the alarm? It's like what most CRX owners do. Where they drill the door jamb and install it. I don't really care about getting into the car by the trunk when the batteries die....
Old Nov 26, 2003 | 04:10 AM
vigor5spd's Avatar
Default Re: Wiring separate power door lock selenoids to work with OEM power doorlocks (neuspeed)
Why dont u you just disable your manual door locks? Take your door panels off and unlatch it. Only way to unlock your doors is with your key or keyless entry.
Old Nov 26, 2003 | 04:28 AM
Jay J's Avatar
Prince of Zamunda
Default Re: Wiring separate power door lock selenoids to work with OEM power doorlocks (vigor5spd)
I was asking about installing 2 door locks on each door.. Even if a theif does slim jim the door he still can't get in because of the separate door selenoid in the way. Which some CRX owners wire up to their car. How ever CRX's here didn't come with OEM power door locks so the owners just hook up those selenoid door locks to the brain of the alarm. I'm asking if I can make both work with the alarm at the same time.
Old Nov 26, 2003 | 02:37 PM
B18C_EJ8's Avatar
Most alarms have a limited current outputs... If you drive one set of solenoids with the output, you may have to trigger the other set with a relay....
crx_si-r
20
Jan 4, 2010 12:35 PM
aimbot
Jul 11, 2008 08:09 AM
saveacivic
Audio / Security / Video
21
Jan 24, 2007 07:18 PM
AgentJam
22
Feb 2, 2004 06:58 AM
jaM3s Bond
Mar 5, 2003 11:47 AM
