Hp for mid-to-low 13's?
i am guessing about 205whp......around stock weight......but you can achieve this more easily if u do some major diets......fiber glass trunk, cutted interior, remove front and rear bumper support brace sound deaning, convert to crx drum brakes little....rollin rear HX wheels lighter basically make it light as possible or u can just turbo your currrent LS and be there with slicks...
lighter car less hp to achieve those times
heavier car more hp it takes to achieve those times
simple as that
go http://www.aspracing.com......do to online dyno figure it out.....weight of car and whp.....but remember those times are under perfect traction condition
simple as that
stock weight you need more than 200whp to hit mid to low 13's
and thats not going to happen with the non vtec head unless you go boost
You want to be able to put that power to the ground. So tires, motor mounts, suspension will also play major factors, not just pure power.
We cant give you a definite answer, because driver and tires play a huge role but heres an example that may help you
Direp972 Ls revhard kit, 3" exhuast, bfg drag radials 230/200 ran 13.3
BluLuder
Sep 12, 2001 08:29 AM
