drain the gas tank
Old Nov 25, 2003 | 10:41 PM
H22A EG6's Avatar
Default drain the gas tank
how do i drain the gas tank i have not run my car foe 5 months b/c it got a bobo
i think i can drain it form the drain plug b/c that is what it is there for but how do i get gass out if the line do i disconnect the line and let the fuel pump do its job??
all ideas welcomed
Old Nov 26, 2003 | 08:31 AM
H22A EG6's Avatar
Default Re: drain the gas tank (H22A EG6)
20 views and no one knows??
Old Nov 26, 2003 | 08:48 AM
bad-monkey's Avatar
put the car on jackstands and look for the drain bolt on it. it should be relatively easy to find. get something to put it in, and start emptying. i don't think the fuel in the line is going to be that big a deal, but i guess you could disconnect it like you say and get on your throttle and bleed it...
Old Nov 26, 2003 | 11:04 AM
hype r 555's Avatar
Default Re: (bad-monkey)
the best thing to do would be drain the tank and then add half tank of 93+ octane to tank with injector cleaner at the same time , do not run the car until you have done this , what will happen is the 93+ will disolve any unwanted farnish type left overs by basically mixing into the gas present to cause a less combustable mixture,
make sure you by new spak plugs as well ,
the reasoning for the injector cleaner is to brake up the deposists of the old gas left in the plunger end of the injetor to ensure maximum combustability on start up .
but in all reality man .... 5 mnths is not a long time and unless the temp in your area has gotten less than about 20f you ok .
ps. i'm ase and honda cert.
Old Nov 26, 2003 | 11:24 AM
H22A EG6's Avatar
Default Re: (bb4lude)
what bout 110 octaine
Old Nov 26, 2003 | 11:25 AM
H22A EG6's Avatar
Default Re: (H22A EG6)
mn it gets low
Old Nov 26, 2003 | 03:15 PM
99spanishGT
Guest
Posts: n/a
disconect lines
Old Nov 26, 2003 | 11:46 PM
H22A EG6's Avatar
Default Re: (spanishlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spanishlude &raquo;</TD></TR><TR><TD CLASS="quote">disconect lines</TD></TR></TABLE>
and...
Old Nov 27, 2003 | 09:52 AM
JG Luder's Avatar
ciphon that beeyatch... spelling optional
93accord808
Aug 11, 2007 05:37 AM
kornerk12
Mar 18, 2007 09:13 AM
allnaturalb16
Jan 13, 2007 01:17 PM
1 Cam Wonder
30
Oct 21, 2004 10:14 PM
96turboteg
Jul 28, 2004 11:00 AM
