Oil sending unit???? I think
I am reconnecting all the wores on my new d16a6 I just out in my crx and there is a sensor on the back of the block I think it is the oil sending unit or something having to do with it and there is 2 connectors on it and I have three loose wires back there a yellow/green wire a black wire and a red I think....I am wondering where they go so If you were looking at the back of the block with the motor in the car there is a connector on the left and right? where do the wires go??? anyone?
the oil pressure sensor has one wire
look at this pic, its the one that has nothing attached to it
its the one with the nipple pointing at you
thanks to host for this pic..
and the other two wire sensor is for your radiator fan.
..hook both up accordingly and u should be fine.!
good luck.
alright well which color wire goes on the oil pressure sensor and then the other connector........what color wires go where the sensor im talking about is higher up like in the direction the hose from the OPS in the pic is going up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan89crxsi »</TD></TR><TR><TD CLASS="quote">I am reconnecting all the wores on my new d16a6 I just out in my crx and there is a sensor on the back of the block I think it is the oil sending unit or something having to do with it and there is 2 connectors on it and I have three loose wires back there a yellow/green wire a black wire and a red I think....I am wondering where they go so If you were looking at the back of the block with the motor in the car there is a connector on the left and right? where do the wires go??? anyone?</TD></TR></TABLE>
The Yellow/Green and Black go to the 2 prong (coolant temperature switch) sensor. I think the Oil Pressure sensor gets the red wire. Is there a boot on any of the wires? There should be a boot on the Yellow/Green & Black and then one for the Oil Pressure switch.
no I think the boot was ripped off my wiring harness you are right though my friend just came in and told me the green/yellow and black go to the 2 prong sensor and the other is the oil pressure sensor but on the 2 prong sensor which goes on the left and which on the right thats all I need to know now
Does not matter! Its just an on/off switch, so the polarity isn't important. If the polarity mattered, Honda would have keyed the plug somehow so it could only be plugged in one way.
