Help: What kinda Lube should i use to lubricate my Ingalls Camber kit?
It says to use polyurethane greese...is that the best thing to do? Anyone have any experince with this? The camber kit is making a lot of noise and i cant stand it anymore. Any suggestions would help out a lot.
Thanks
Thanks
There are several kinds of grease, but they must be water resistant-like the type sold as "marine grade." You can use Magnalube with has the correct chemical makeup and available from industrial supply houses.
How do you plan on using grease on an Ingalls Kit-there are no fittings for 4th and 5th gen bushings. I would suggest that you try using a silicone or teflon spray lube. Then again do I what I do-nothing--poly bushings are noisy.
Slidingby
Jun 5, 2007 03:24 AM
600_Double_R
Sep 8, 2006 10:01 AM
joedubovik
Nov 29, 2004 09:26 PM
Immortal23
Sep 17, 2001 12:45 PM
