anyone use the hasport EFSI-VTEC ?
Old Nov 25, 2003 | 12:27 PM
-slow ej-'s Avatar
Default anyone use the hasport EFSI-VTEC ?
i just orderd the hasport EFSI-VTEC harness/wires to convert my car from obd-0 to obd-1 and i was wonderin who has ever used that be4 and my question is..is that better than the obd0-1 conversion harnesses that everyone else sells or what?
Old Nov 25, 2003 | 12:32 PM
HT Chaplain's Avatar
Loved
Default Re: anyone use the hasport EFSI-VTEC ? (-RsINtEg-)
I thought that harness was just used to add vtec
Old Nov 25, 2003 | 12:35 PM
-slow ej-'s Avatar
Default Re: anyone use the hasport EFSI-VTEC ? (legutki)
so is it better than the obd-0-1 conversion harneses?
Old Nov 25, 2003 | 12:50 PM
EL Vap133's Avatar
I'm still OBD0...
Old Nov 25, 2003 | 03:07 PM
onePOINTsix's Avatar
Default Re: anyone use the hasport EFSI-VTEC ? (EL Vap133)
hasport harnesses are a waste of money, you can do it your self with little work in 2-3 hours, if you dont have 2-3 hours then your not gonna have time to install the hasport harness, if this is just a conversion harness for a OBD1 ecu in a nonOBD car then thats different, you'll still need to do wiring. if your not confident in your wiring then don't attempt this... ever
Old Nov 25, 2003 | 03:18 PM
APEX CRX's Avatar
your talkin about 2 different things. the Hasport harness adds Vtec, oil pressure, o2 sensor and knock sensor for b16's the conversion hardness (OBD-0 to OBD-1) is the jumper harness between your stock ECU harness to the new ECU
88zchatch
15
Mar 20, 2009 12:06 PM
bobbyisking
Jul 7, 2008 09:22 AM
cdndna
Feb 6, 2006 11:11 AM
aVstAr
Dec 10, 2005 05:08 PM
SI_Ro
Dec 13, 2003 01:49 PM
