B16 ECU QUESTION
Old Sep 14, 2001 | 12:49 PM
GeeSeeR's Avatar
New User
Default B16 ECU QUESTION
Well my B16 in my crx has been running allright so I took it to the track, needless to say I am very disappointed with the times. A Guy who owns a local shop suggested that the ECU might be from an automatic B16. Does anyone know how to tell the difference between the two.
Old Sep 14, 2001 | 01:06 PM
JimmieD's Avatar
Default Re: B16 ECU QUESTION (GeeSeeR)
I thought you said it felt much faster than the last car. Let me know what you find out and how you did.
Old Sep 14, 2001 | 01:09 PM
RyanR's Avatar
The revlimiter should kick in around 8200rpm. On auto ECU's it kicks in around 7600-7800. Also, if you take off the ECU cover and look at the small circuit board(knock sensor board), it should say MT on one of the corners. If it says AT then you have an auto ECU.
Old Sep 14, 2001 | 02:27 PM
WONG FRIED RICE's Avatar
what time did you get? what other mods do you have? ur time depends on circumstances as well...like shifting, excesive wheelspin, launch, blah blah blah...i'm pretty sure you heard it all before
i was also disappointed my first time up to the track with the b16 in my crx...i clocked a best time of 15.3 w/ i/h/e , fields-vtec, and cam gears....but i spun alot of rubber
[Modified by JDMB16ACRX, 3:33 PM 9/14/2001]
Old Sep 14, 2001 | 10:33 PM
raene's Avatar
Default Re: B16 ECU QUESTION (JDMB16ACRX)
First times at the track are always disappointing... I ran a 15.5 first run . Sure felt faster though!
Tonight I ran a worst time of 17.87 . Hooray for missed shifts!
Old Sep 15, 2001 | 04:45 AM
GeeSeeR's Avatar
New User
Default Re: B16 ECU QUESTION (raene)
I ran a 17.00 with the car. The runs weren't bad either, and i noticed that the rev limiter did kick on at less then 8000 rpm.
Old Sep 15, 2001 | 07:11 AM
GeeSeeR's Avatar
New User
Hey 97 typeR thanks for the reply. I took off the cover and sure enough it had an AT on the small circuit board in the corner, well I guess that will take care of my problem. Anyone know where I can get another ECU for a good price?
Old Sep 15, 2001 | 11:09 AM
FourDoorGSR's Avatar
i'm not exactly sure about this one...but try jdmhondaparts.com??
Old Sep 15, 2001 | 11:21 AM
RyanR's Avatar
Just get it reprogrammed. Katman at jdmhondaparts can reprogram auto ecu's to manual and you get a better program. I think he charges $155 for the service.
efkilla
Mar 21, 2011 11:34 AM
themex77
Jun 13, 2007 08:54 PM
joecrxsi
Jul 22, 2004 01:35 PM
89EF9
Dec 2, 2002 12:41 PM
