Rattle from Instrument Panel
Old Nov 25, 2003 | 07:11 AM
JOEP's Avatar
Default Rattle from Insturment Panel
One thing I have noticed is that when I hold it at 4000rpm or so I get a rattle sound from somewhere around my instrument panel.....
Any ideas? Anyone have this prob before?
Cheers
Old Nov 25, 2003 | 08:26 AM
Bbasso's Avatar
Default Re: Rattle from Insturment Panel (JOEP)
did you try hitting the dash? not hard,but enough to maybe stop it...
and are you sure its not coming from the loose change in the ashtray?
Old Nov 25, 2003 | 08:31 AM
RTW DC2R's Avatar
Default Re: Rattle from Insturment Panel (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">did you try hitting the dash? not hard,but enough to maybe stop it...
and are you sure its not coming from the loose change in the ashtray?</TD></TR></TABLE>
youre so violent vans, dashboards...Im surprised you didnt just try to PLOW through those deer on the way back from LRP
seriously though, pull out your cluster, and put some foam wrap around the harness wires and see if it still rattles.
Old Nov 25, 2003 | 08:45 AM
Bbasso's Avatar
Default Re: Rattle from Insturment Panel (RTW DC2)
"Im surprised you didnt just try to PLOW through those deer on the way back from LRP"
Hey if I was going faster I just might have
Old Nov 25, 2003 | 11:27 AM
JOEP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
seriously though, pull out your cluster, and put some foam wrap around the harness wires and see if it still rattles. </TD></TR></TABLE>
I'll give that a try.... thanks.
Old Nov 25, 2003 | 11:30 AM
py1188's Avatar
I have the same thing but in my beater. It sounds like its coming from the gauge cluster itself. Is that even possible??
Old Nov 25, 2003 | 11:52 AM
JOEP's Avatar
Default Re: Rattle from Insturment Panel (py1188)
The rattle is definitley coming from somewhere behind the guages so the wiring or the screws holding the cluster might need some tightening...... its not a big deal just a little annoying.
Old Nov 25, 2003 | 11:53 AM
jdmspoonitr's Avatar
Probably one of the three screws holding the cluster in.
Old Nov 25, 2003 | 04:07 PM
IvTecR's Avatar
Default Re: Rattle from Insturment Panel (jdmspoonitr)
a loose screw... i had this problem in a beater, thought it was from the cluster but ended up being a loose screw from below the steering wheel. weird. after that, it didn't rattle again
Old Nov 25, 2003 | 05:22 PM
Philly_NBP_R's Avatar
Default Re: Rattle from Insturment Panel (IvTecR)
I've got an annoying squeak coming from the passenger side of the dashboard - any ideas?
(stoopid rattletrap Honda... )
liketofry
Honda Civic (2006 - 2015)
Oct 13, 2006 08:08 AM
maxboost_50psi
Jun 11, 2006 03:04 PM
mykal
13
Sep 30, 2004 09:46 AM
AmginE
Apr 6, 2004 03:40 PM
dmecarboy
Feb 1, 2004 07:38 PM
