Tire size on rims
Old Nov 25, 2003 | 06:29 AM
FalconMan's Avatar
Default Tire size on rims
What would be a good size for a tires on 17's
i found 205/40/17 ..... is this good or something else be better
Old Nov 25, 2003 | 06:55 AM
bad-monkey's Avatar
Default Re: Tire size on rims (FalconMan)
205/40/17 works, 215/40/17 works.
Old Nov 25, 2003 | 07:39 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Tire size on rims (bad-monkey)
the wider the better.
Old Nov 25, 2003 | 08:04 AM
SweepeR 7's Avatar
Default Re: Tire size on rims (Sticky Tires)
my friend has 205's on his CRX and it is sticking out liek about half an inch. if i were to put 215 on my prelude would it stick out as well? i dont want to buy the tire then get assed out you know.
Old Nov 25, 2003 | 12:15 PM
FalconMan's Avatar
Default Re: Tire size on rims (SweepeR 7)
same with me from above
Old Nov 25, 2003 | 12:33 PM
00LudeSH's Avatar
i run 215/40/17 with no rubbing
Old Nov 25, 2003 | 12:40 PM
JTCdudeman's Avatar
Master H Technician
I would advise 215/40/17... For the reasons of more tire in both direction.. We like more surface area for grip and speed purposes.. those two intertwine honestly.. But I like the 215's because you get another 2.5 cm of height to your tire.. This may seem insignificant.. But, I like to think of pot holes and added protection for my rims.. Also, you gotta ride on the ground to not get that wheel gap of a 4x4 with 205's... Just my 2 cents.. And no, 2.5cms wont be a big thing like I just implied... But, it is noticeable with the tires next to each other..
Old Nov 25, 2003 | 12:47 PM
FalconMan's Avatar
ok thanks
Old Nov 25, 2003 | 02:24 PM
prelude1897's Avatar
Default Re: (FalconMan)
P205/40R17 tires would work
brzrkr
Sep 18, 2008 11:03 AM
no1knows908
Jan 25, 2008 06:54 PM
takenbycause21
Jan 31, 2005 03:31 PM
SpeedMonkeyRacing
Jun 21, 2002 02:31 PM
1tuffex
Mar 16, 2002 12:54 PM
