Omg Thieves Suck - What Can Be Done
Old Nov 24, 2003 | 09:07 PM
EF-Pimp's Avatar
Default Omg Thieves Suck - What Can Be Done
k
Modified by EF-Pimp at 12:11 AM 12/11/2003
Old Nov 24, 2003 | 09:57 PM
inzaneN1's Avatar
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
Default Re: Omg Thieves Suck - What Can Be Done (EF-Pimp)
dont recommend pulling ecu cuz then ur gonna have to be waiting five minutes after u start ur car to let it reset . best thing i can tell u is autolock, kill switches , pulling starter fuse, club(even if it slows them down a bit) ,removable steering wheel , **** it jack up ur car and take a wheel off
Old Nov 25, 2003 | 09:49 AM
Beach Accord's Avatar
Default Re: Omg Thieves Suck - What Can Be Done (inzane)
find out if it was towed or simply hot-wired. ask the owner he will probably know. if it was just hot-wired then i would get a club\autolock combo and pull some fuses maybe even take a trip to radio shack for some kill switch material. That should keep these thieves away. If it was towed, you may just be delaying the inevitable. good luck
-chris B
Old Nov 25, 2003 | 10:57 AM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-Pimp &raquo;</TD></TR><TR><TD CLASS="quote">I have a show car with about 3k of audio and engine work and a **** load of body mods so I have no idea why they didnt touch my car. </TD></TR></TABLE>
simple really - yours is easier to track and sticks out like a sore thumb. Also, they may have wanted just simple transportation. In addition, the corsica may have not had an alarm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">HERES THE PROBLEM:
They actually stole his car, thats the only thing Im worried about. I dont care if they break in because all of my audio **** is concealed and would take a while to be ale to get at then steal. All I want is something I can do that will absolutely guarantee my car will no go anywhere. What can be done?</TD></TR></TABLE>
Nothing is a guarentee - the end all be all is that if they want it, they will take it. It's that simple. I will never understand people who put lots of money into a car without a secure place to park it. It's a shame that it has to be that way, but it's the reality of life.
all you can do at this point, is make it very unattractive for a theif to target your car. Make it so that it's more tempting to steal the car next to you rather then your ride.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Is there a fuse or something I can pull that a good thief would not carry?
I want something a good thief wouldnt have on them that I can take out but dont want to carry around something huge with me. I was thinking ecu? How hard is it to pull/install? Looking for anyhting because I dont care if they get a crack at my audio because my alarm is there and we now have a security guard but she isnt always around so if they started my car and stripped it I would be royally fucked. Audio can be replaced. The 100's of hours I put into the body work and paint wont.
Thanks</TD></TR></TABLE>
Pulling the ECU all the time is a PITA. On classic cars we used to pull the coil wire from the ignition system - car is dead without one. Then again, theives carry one around with them.
I think that you should consider adding a more sophisticated alarm with perhaps a pager system.
Old Nov 25, 2003 | 03:13 PM
B18Jake's Avatar
What i would do is 1. good alarm 2. instal a metal "spacer" below the window so slim jims can not go lower then 3inches or so. 3. Removable stering wheel. 4. A switch consealed under your dash ... some place only you know, that cuts battery power. With that **** your car will be perfectly safe. Good Luck
Old Nov 25, 2003 | 03:21 PM
rcurley55's Avatar
New User
Default Re: Omg Thieves Suck - What Can Be Done (B18Jake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Jake &raquo;</TD></TR><TR><TD CLASS="quote"> 3. Removable stering wheel.
With that **** your car will be perfectly safe. Good Luck</TD></TR></TABLE>
Umm yeah...and perfectly unsafe when he gets into an accident - removing an air bag from a car as a theft deterrent --- probably the worst advice I've ever read IMHO...
Old Nov 25, 2003 | 04:33 PM
EF-Pimp's Avatar
Default Re: Omg Thieves Suck - What Can Be Done (rcurley55)
k
Old Nov 25, 2003 | 05:43 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-Pimp &raquo;</TD></TR><TR><TD CLASS="quote">car doesnt have an airbag anyways, I think one of these switches to my battery would be sick. All I need is a basic switch from radio shack right and just put it somewhere concealed and just splice it into the battery wire?</TD></TR></TABLE>
sorry I missed that in your sig....my apologies...
Old Nov 25, 2003 | 10:57 PM
Heat's Avatar
Somebody stole a '92 Corsica? They had to have seen the car before and known it was loaded with equipment, nobody looks at a Corsica and says "man, I want that car real bad and am willing to spend years in jail to make it mine".
And I know a little about Corsicas, my commuter car is an '88 Corsica.
Old Nov 27, 2003 | 12:54 PM
Jimmy's Avatar
Global Moderator
Default Re: Omg Thieves Suck - What Can Be Done (Heat)
Put wheel locks on it (they will haft to take the wheel off).
Pull your ecu fuse ( car will not start & you dont haft to wait 5 mins )
Install a fuel pump cut off switch.
Old Dec 7, 2003 | 01:45 PM
egturbo's Avatar
from what i hear. i wish that it was done to u.. u bastard.. i know this is riceracist.. i want my kit..
Old Dec 8, 2003 | 02:30 AM
sohcvtec66
Guest
Posts: n/a
Default Re: Omg Thieves Suck - What Can Be Done (egturbo)
yah, did anyone buy your JDM tails... or did u take there money too, ef-pimp is riceracist.. look at both the profile, kevin st john, wierd they both have the same name,
Old Dec 8, 2003 | 04:39 AM
lost_sol's Avatar
i have a kill switch in my car w/ a 2-way alarm..pretty reilable..i don't know where you could get one installed though bc it came w/ the car...when i say kill switch, it's actually a lil key w/ some chip in it under my dah so i can take it out everytime i park my car like a normal key..w/o it not startable
Old Dec 8, 2003 | 04:44 AM
o_Rage_o's Avatar
Default Re: (lost_sol)
BEST TWO MODS...get them done the next weekend you have a chance
1) Relocate hood wire - The stock hoodwire runs underneath the driver fender...one knife and a pull on the wire and up pops the trunk.
instructions can be posted if necessary...(also at team-integra)
2) Manual or automatic fuel cuts - Even if you just connect a relay and a switch to intterupt the fuel system electricals somewhere in the car, its better than nothing and a PITA for anyone breaking in..
Then again, none of this stops someone from just towing the car
-Rage
Old Dec 8, 2003 | 04:45 AM
o_Rage_o's Avatar
Default Re: (o_Rage_o)
big ups to T.O :D
-Shane
Old Dec 8, 2003 | 05:56 AM
xvietxkhmerxboix's Avatar
Thieves are bad so are scammers READ THIS https://honda-tech.com/zerothread?id=680112, information you all might not know about Ef-pimp
Old Dec 8, 2003 | 10:26 AM
dezznuttz's Avatar
thats a stupid idea!! no power would be feeding your alarm......think about it
Old Dec 8, 2003 | 10:32 AM
dezznuttz's Avatar
just another quick answer to the towing thing just buy this http://www.alphalock.com/ this should help alot and would be worth your bucks......
Old Dec 8, 2003 | 12:56 PM
Dveloped's Avatar
Default Re: (dezznuttz)
get the new directed/viper/clifford GPS tracking system and the alarm with up to 2500 coverage for your deductible.... oh and give all your receipts to your insurance company..
Old Dec 8, 2003 | 02:09 PM
4uhataz's Avatar
You have to be more clever than the thief. Even the best of them cannot start a well protected vehicle. I know, because I have one that they tried to hijack! Kill switches in well hidden places, and start sequences that shut down the computer, or the entire electrical system for about 20 minutes are great!
Old Dec 8, 2003 | 02:29 PM
rjr162's Avatar
you'd need a damn powerful switch or relay to cut the mail power line.
Oh, and I just noticed all the threads posted about how you're a damn scammer. Don't know if it's true or not but you have enough damn ppl talking crap about you... If so, I'm not giving you any advice because I hate ppl that scam
Old Dec 8, 2003 | 02:53 PM
Default Re: Omg Thieves Suck - What Can Be Done (rjr162)
(hmm)
Old Dec 8, 2003 | 05:43 PM
crxnic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Jake &raquo;</TD></TR><TR><TD CLASS="quote">What i would do is 1. good alarm 2. instal a metal "spacer" below the window so slim jims can not go lower then 3inches or so. 3. Removable stering wheel. 4. A switch consealed under your dash ... some place only you know, that cuts battery power. With that **** your car will be perfectly safe. Good Luck</TD></TR></TABLE>
Great Idea! ^^^^ Im going to do the same.
Old Dec 8, 2003 | 08:39 PM
Got Some Rice's Avatar
I heard that creating multiple dupe accounts is a good anti-theft device. Maybe you should make another one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and I just noticed all the threads posted about how you're a damn scammer. Don't know if it's true or not but you have enough damn ppl talking crap about you... If so, I'm not giving you any advice because I hate ppl that scam</TD></TR></TABLE>
That's because he is. Read this thread - his post before the edit was "I don't wanna take it if its gonna skip" and a pair of s directed at me. Too bad your dupe account using *** just got OWNED by a trial member eh EF-Pimp?
Old Dec 8, 2003 | 11:24 PM
Default Re: Omg Thieves Suck - What Can Be Done (Got Some Rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Some Rice &raquo;</TD></TR><TR><TD CLASS="quote">I heard that creating multiple dupe accounts is a good anti-theft device. Maybe you should make another one?
That's because he is. Read this thread - his post before the edit was "I don't wanna take it if its gonna skip" and a pair of s directed at me. Too bad your dupe account using *** just got OWNED by a trial member eh EF-Pimp?</TD></TR></TABLE>
hmm again
