Steering wheel vibration
The steering wheel on my CRX vibrates so much sometimes it makes noise... it literally blurs as it's shaking around. If I grab it the vibration is lessened a lot. Is there any way to tighten it up, or is this normal?
There are a few things it could be. Either a bent rim, worn ball joints, worn outer tie rods, warped rotors or worn wheel bearings. If you have warped rotors then you'll usually only get vibration under braking.
Mine used to do that.....and the steering would wander a lot on the highway. Once I replaced the rack, it tightened right up and stopped vibrating.
yeah mine does that **** too..
the faster i go the worse it is.
im pretty sure mines a combo of bad alignment and warped rotors.
mine makes noise too dudduddudduddududududududud
[Modified by 91ED7Si, 11:21 PM 9/14/2001]
Sorry that was totally unclear
. It only vibrates at idle... it's solid at speed.
I'd think it was the mounts too except that it used to do that with the D16A6 too. I just thought it was normal.
. It only vibrates at idle... it's solid at speed.I'd think it was the mounts too except that it used to do that with the D16A6 too. I just thought it was normal.
how is your idle?? your idle could be the cause. and i think you were saying you have a b16 w/ idle probs right? i may be wrong it was on another post. if you are haveing idle problems that could def be it. mine does it only when it drops below 750rpms
miked198729
Aug 17, 2013 06:38 AM
teletekman
May 3, 2006 09:15 AM
