Install: Valve Stem Seals?
Old Nov 24, 2003 | 05:56 PM
Jimmy's Avatar
Global Moderator
Default Install: Valve Stem Seals?
Ok..I have yet to do a compression test on my motor [D16Z6].
I have smoke when i first start my car up (a little more then normal)
While on WOT i get smoke also.. My motor has 97,000 Miles..Mods include I/H/E
Also the motor doesnt burn oil.
I plan on replacing my valve stem seals real soon.
Does anyone have any tips..or Write ups on the best and easiest way to do this without making it a big deal.Also should i buy oem valve stem seals or just pick some up from autozone,etc?
How much am i looking to pay for each seal?
We could use some help if anyone is local and i would be willing to pay you.
I live in knoxville,tn. TIA
Old Nov 24, 2003 | 06:04 PM
93civicEX's Avatar
Default Re: Install: Valve Stem Seals? (USDMDC2)
I think I paid 28 dollars for all of the seals both intake and exhaust
Old Nov 24, 2003 | 06:09 PM
Jimmy's Avatar
Global Moderator
Default Re: Install: Valve Stem Seals? (93civicEX)
Thank you..Where did you buy them from and why did you haft to replace yours?
Are they holding up well if theyre not oem?
Old Nov 24, 2003 | 06:26 PM
tonyxcom's Avatar
Get OEM, they are 2 bux a peice give or rape from your dealer.
There is a special tools that my machine shop guy had that I used to put mine on, and take the old ones off.
I dont know how important it is to use that specific tool, but it sure made it easy to get them lined up and pounded on.
Old Nov 24, 2003 | 06:29 PM
Jimmy's Avatar
Global Moderator
Default Re: Install: Valve Stem Seals? (tonyXcom)
How much did they charge you?
Also how much time am i looking to spend on this doing it the right way?
Old Nov 24, 2003 | 06:40 PM
Jimmy's Avatar
Global Moderator
Bump..anyone else ANY help would be appriciated
Old Nov 24, 2003 | 06:44 PM
chad's Avatar
Moderator
mostlikely the smoke is from bad RINGS not seals....i took my head off to put a 1 layer hg on and while i was at it put new valve stem seals in hoping that would fix problem...nope...it was the rings
Old Nov 24, 2003 | 06:47 PM
Jimmy's Avatar
Global Moderator
Default Re: Install: Valve Stem Seals? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">mostlikely the smoke is from bad RINGS not seals....i took my head off to put a 1 layer hg on and while i was at it put new valve stem seals in hoping that would fix problem...nope...it was the rings</TD></TR></TABLE>
Bad rings mean your burn oil to right?
My car doesnt burn any oil and it doesnt smoke constanly
just when i start it up (like maybe oil dropped into the combustion chambers over night by having bad valve stem seals) and after it warms up it doesnt really smoke
but then at WOT it smokes a little not a real lot but enough to notice.
tonyxcom's Avatar
They didn't charge me anything actually. With the head dissasembled and off the car. changing all of the valve seals on my dohc head took roughly 20 mins.
Old Nov 24, 2003 | 07:39 PM
Hammett's Avatar
blue smoke ?? white smoke?? black??
Old Nov 25, 2003 | 04:57 AM
Jimmy's Avatar
Global Moderator
Default Re: Install: Valve Stem Seals? (Hammett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hammett &raquo;</TD></TR><TR><TD CLASS="quote">blue smoke ?? white smoke?? black??</TD></TR></TABLE>
Sorry i dont know.
ttt/bump
insidiouseg-6
Apr 14, 2009 04:34 PM
pat91hb
15
Jul 6, 2008 09:02 AM
crexer
Dec 21, 2006 12:30 PM
Takumi Fujiwara
Sep 6, 2005 02:42 PM
