cutting your own head flange
Old Nov 24, 2003 | 01:18 PM
Optiks.'s Avatar
Default cutting your own head flange
i have acsess to a plasma cutter at school. and was wondering how hard it is to make my own head flange, i was thiinking of ordering a gasket to trace and then cut it with the plasma and then clean it up with a die grinder and some nice burrs, anyone else done this? can you give me some tips
Old Nov 24, 2003 | 01:20 PM
matt_sb2000's Avatar
Default Re: cutting your own head flange (Optiks)
Don't bother unless the plasma cutter is rated for 3/4" or more...
If you use a 1/2" machine on a piece of 1/2" you will end up with a hideous piece of metal that kind of resembles a flange.
Old Nov 24, 2003 | 02:17 PM
Optiks.'s Avatar
Default Re: cutting your own head flange (matt_sb2000)
i think the peice i wanted to use is 1/4" is that too thin
Old Nov 24, 2003 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks &raquo;</TD></TR><TR><TD CLASS="quote">i think the peice i wanted to use is 1/4" is that too thin</TD></TR></TABLE>
For a turbo manifold yes. For a header no.
Old Nov 24, 2003 | 02:19 PM
redboost10's Avatar
look at http://www.alphatuning.com, their head flange is 1/2" thick, i think 1/4" would be too thin for a head flange
Old Nov 24, 2003 | 02:25 PM
Optiks.'s Avatar
just wondering why its too thin for a turbo mani
Old Nov 24, 2003 | 02:30 PM
spoolinlude's Avatar
I live under a rock
I use 1/2" steel to make my flanges, and good luck with a plasma cutter, you're gonna be all over the place and have a pretty shitty looking rough cut flange when you're all done, which means grinding the snot out of it....... my way works better....... CNC.... nuff said, you're school should have one of them if they got a plasma torch...... so learn how to use it
Old Nov 24, 2003 | 02:33 PM
Optiks.'s Avatar
Default Re: cutting your own head flange (jz)
will it warp terribly?
Old Nov 24, 2003 | 02:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks &raquo;</TD></TR><TR><TD CLASS="quote">just wondering why its too thin for a turbo mani</TD></TR></TABLE>
It will warp really really bad when you weld it... And it isn't strong enough to pull back down when you try to bolt it to the head...
Also, it is so thin that if you try to surface it there will be no more flange.
Old Nov 24, 2003 | 03:02 PM
Optiks.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_sb2000 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> what you mean by this
Old Nov 25, 2003 | 09:14 AM
Joseph Davis's Avatar
1/4" is not thick enough for NA.
3/8" for NA, 1/2" for turbo. The metal is simply too thin to support it's own weight when hot + warps if you go smaller.
And $50 for a flange is a bit much... at those prices I'd whip out a drill and holesaw and make one - I have before. But, thankfully, you don't have to pay $50... http://www.overblownmotorsports.com has them for a good deal.
FYI, Todd's spending Thanksgiving at my house, he won't be able to reply to emails until next monday or tues.
Old Nov 25, 2003 | 09:18 AM
legendboy's Avatar
Default Re: cutting your own head flange (J. Davis)
Hey thanks for the link J. Thoes are cheap cheap cheap!
Old Nov 25, 2003 | 09:22 AM
Default Re: cutting your own head flange (legendboy)
He buys them in bulk, and doesn't try to Import Auto Salvage you.
Old Nov 25, 2003 | 09:39 AM
Overblown-Teg's Avatar
yeah guys buying in bulk helps me out so I sell them for near cost.. I litterally only make a buck or two off each one.. Right now I am out though.. I hope to order some more soon. If anyone wanted to put together a group buy for about 5-10 it would help me out a ton and I can keep the same prices.. I need to order 20 for that pricing, more and its probably a little less..
Old Nov 25, 2003 | 12:31 PM
spooln6's Avatar
Default Re: cutting your own head flange (Overblown-Teg)
i used a manual mill to do mine although cnc is much nicer. And yes 1/4" is to thin
Old Nov 25, 2003 | 01:38 PM
Optiks.'s Avatar
just to toss this in for the sake of arguement doesnt this flange look really close to 1/4 inch
Old Nov 25, 2003 | 02:02 PM
.RTErnie's Avatar
looks like 3/8's to me.
Old Nov 25, 2003 | 03:53 PM
Optiks.'s Avatar
lol ill try tomorow on my fre 1/4" peice if it doesnt work out then ill buy one
Old Nov 25, 2003 | 06:15 PM
legendboy's Avatar
don't waste your time with 1/4". My very first diy turbo kit used a 1/4" flange and it warped/leaked etc...
You can cut your own flange with a torch or a small plasma cutter, but your going to need to get it machined flat after you finish your manifold. (it will cost more than buying a flange!) I have the smallest hypertherm plasma, rated only for 3/8" rough cut and i did 1/2" head flange. Took a long time tho, and lots of cleanup after.
Old Nov 25, 2003 | 07:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">1/4" is not thick enough for NA.
I disagree.... I have seen alot of headers for v8's that use 1/4" flanges.
I suppose that it all depends on what gauge tubing you are using, and how long the primaries are. Long with thin wall tubing = fairly flexible ****. So 1/4" flanges will work. You do have to cut them between the ports though.
Old Nov 25, 2003 | 08:08 PM
.RTErnie's Avatar
try bolting your flange to your head or spare chunk of steel when you weld them...it will save you money on machining
Old Nov 25, 2003 | 09:57 PM
I disagree.... I have seen alot of headers for v8's that use 1/4" flanges. </TD></TR></TABLE>
I've seen a lot of cheap pieces of **** that leak, too.
If you have to make it once, make it correctly.
I've made headers before, I sand bend my own pipe, and less than 3/8" flange is substandard for a 75 hp Spitfire much less anything that puts out any real power/heat.
Old Nov 25, 2003 | 11:40 PM
Mista Bone's Avatar
D Tranny Guru
high powered CNC Laser cutter..........
3/8", $24.
Old Nov 26, 2003 | 01:08 AM
.RTErnie's Avatar
Default Re: cutting your own head flange (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">high powered CNC Laser cutter..........
3/8", $24.</TD></TR></TABLE>
NUF SAID...so go ******* buy one!
Old Nov 26, 2003 | 08:53 AM
I've made headers before, I sand bend my own pipe, and less than 3/8" flange is substandard for a 75 hp Spitfire much less anything that puts out any real power/heat.</TD></TR></TABLE>
At least you admit having seen a 1/4" header flange.
