My ZC blew a hole in my muffler and cracked the exhaust pipe!
Old Nov 24, 2003 | 12:44 PM
giantdumbass's Avatar
Default My ZC blew a hole in my muffler and cracked the exhaust pipe!
So I went out for lunch at work today, and as I'm driving back from work I start to hear a thunk and the sound of metal dragging. I knew it was exhaust as it's stock still and it is all rust basically. It had cracked and broken in the bend right after the resonator and the muffler had a huge 4'' hole in it. I had been planning on getting a new system but now I have no choice! Do you guys think it was the back pressure or just a little bump + rust and 13 years of driving? Both of these happened at the same time, I'm sure because I had been under there this weekend and everything was rusty but ok.
Anyways, the guy I bought the car from is working out of a local shop now and said he'll have a new 2.25'' Magnaflow system on for me tomarrow. He is charging $375, which seems a bit high, but that does include the muffler and the resonator, plus I don't have to let it go for long. $375 isn't too much is it?
Old Nov 24, 2003 | 01:29 PM
notfastenough's Avatar
Even if it's mandrel, I think it is pricey. Unless you are picking up a nice resonator that is also 2.25.
Old Nov 24, 2003 | 01:36 PM
Sikocivic's Avatar
Default Re: (notfastenough)
If it's stainless, then thats a good deal. If it's not stainless then I think thats too much.
Old Nov 24, 2003 | 02:18 PM
He's also putting on a good 2.25'' resonator (not sure what kind). I figure even if it is a little high he is 100 feet from my house and I'll have it tomarrow.
Old Nov 24, 2003 | 02:47 PM
chadmasterc's Avatar
Default Re: (91rexinva)
Its a decent deal if its mandrel bent, if its crush bent generic muffler shop stuff then its not.
Old Nov 24, 2003 | 11:09 PM
CRX-RX's Avatar
Default Re: (chadmasterc)
Hahahaha. That's what happens when you don't prep the chassis for the motor. My freind blew through six midas mufflers before finally buying a catback. His car was all stock except for an old school racing header. High RPM plus a shitty exhaust that was probably falling apart insde as well = boom.
Old Nov 24, 2003 | 11:36 PM
89s1's Avatar
Default Re: (CRX-RX)
double check that your engine isnt running too rich. (hold a sheet of white paper an inch from the tailpipe and see how many, if any, little black specs you see.)
hold it there for a good 10-15 seconds.
the more/bigger then black specs the richer you are.
SunnyF23Vtec
Oct 3, 2010 04:36 PM
chiaxi2002
Aug 5, 2009 12:58 PM
Andrew Marquis
19
May 1, 2006 10:36 AM
2ndName
Dec 18, 2005 08:39 PM
muskrat
Mar 25, 2003 10:24 AM
