Suspension Techniques + Need reinforcement?
Old Nov 24, 2003 | 12:18 PM
plusONE jboy's Avatar
Default Suspension Techniques + Need reinforcement?
Just curious when using a ST sway bar kit, should you reinforce the subframe with an additional kit? Or is it fine to just bolt on the ST kit by itself?
Old Nov 24, 2003 | 05:33 PM
Default Re: Suspension Techniques + Need reinforcement? (5thgenh4tch)
bump
Old Nov 26, 2003 | 09:09 PM
Old Nov 26, 2003 | 10:10 PM
eg6sir-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenh4tch &raquo;</TD></TR><TR><TD CLASS="quote">Just curious when using a ST sway bar kit, should you reinforce the subframe with an additional kit? Or is it fine to just bolt on the ST kit by itself? </TD></TR></TABLE>
i have a friend that had his st rear sway installed on his 93lx 4door back in 95 without reinforcement kit. and it runs and eats corners like an obese american. i'ved had my st rear sway on my 95ex coupe for the past 3 years now without reinforcement and still takes turns like a fat kid loves cake.
Modified by eg6si at 11:36 PM 11/26/2003
Old Nov 26, 2003 | 10:14 PM
Egone's Avatar
would also like to know bought my st rear sway bar used so no instructions
Old Nov 26, 2003 | 10:23 PM
KillerWabbit's Avatar
I had the ST 19mm rear bar for over a year on my 93 Si with no problems at all. I don't think a 19mm bar is strong enough to tear anything.
Just last week I got the Beaks 22mm ITR bar because 19mm was too small.
Old Nov 27, 2003 | 12:45 AM
PinoyShadow's Avatar
Default Re: Suspension Techniques + Need reinforcement? (eg6si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6si &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by eg6si at 11:36 PM 11/26/2003</TD></TR></TABLE>
HAHAHAHAHA
Old Nov 27, 2003 | 11:16 AM
ahhahahaha, thanks for your imput.
Zulu888
Aug 17, 2006 07:43 AM
vietnameeh
Suspension & Brakes
Jan 10, 2006 06:01 PM
Maxboost808
Jun 16, 2004 02:01 PM
The Internet Tough Guy
Oct 8, 2003 07:00 AM
Kev95lx
Sep 26, 2003 05:54 AM
