integra idles at 1500-2000 rpm!
Old Nov 24, 2003 | 11:49 AM
its WANG yoO's Avatar
Default integra idles at 1500-2000 rpm!
i just put JDM itr swap in my 00' LS...its idling at 1500-2000 rpm...why? i broke the TPS sensor puttin in the swap...and used one from a 99 Ex...would that make it idle high?
Old Nov 24, 2003 | 12:15 PM
doublejz's Avatar
Default Re: integra idles at 1500-2000 rpm! (inJDMtegra)
did you recalibrate it correctly?
Old Nov 24, 2003 | 02:36 PM
Muckman's Avatar
Moderator in Chief
if no CELs then
vaccum leak = high idle
Old Nov 24, 2003 | 03:10 PM
Default Re: integra idles at 1500-2000 rpm! (Muckman)
throwin some codes-
7 TPS - throttle position sensor
10 IAT - intake air temperature sensor
54 CKF - crank fluctuation sensor
code 54 doesn't matter...JDM motors don't have CKF
why would 7 and 10 be throwing? and is that the reason for my high idle?
if i unplug the TPS sensor...the car doesn't change in idle...it should die..if that is unplugged...are all honda TPS sensors the same? i used one from a Civic Ex motor...also...where is the intake temp sensor? and what color wires should go to it?
Old Nov 24, 2003 | 04:36 PM
doublejz's Avatar
well code 7 is either due to it not being calibrated or its bad. code 10 probably try cleaning it first, if that doesn't work replace it. those two are the reason for your high idle. code 54 wont make your car run any different then normal.
Old Nov 24, 2003 | 04:58 PM
Default Re: integra idles at 1500-2000 rpm! (doublejz)
re calibrate? how do i do that?
Old Nov 24, 2003 | 05:58 PM
Old Nov 25, 2003 | 04:18 AM
EE_Chris's Avatar
You need a multi-meter to measure the TPS voltage @ idle: It needs to be <.5v
So the act of recalibrating it is simply rotating the TPS to achieve this output voltage. If you don't have a multi-meter, your SOL.
Old Nov 28, 2003 | 05:28 AM
Default Re: integra idles at 1500-2000 rpm! (EE_Chris)
can't i just rotate it till the car idles right?
Old Nov 30, 2003 | 09:39 AM
92vx6's Avatar
check ur radiator
RiTtEk401
Oct 4, 2011 02:52 AM
reed857
29
Jul 26, 2009 10:57 AM
92eg6_pino
Aug 16, 2005 07:53 PM
smokinsi
Jul 18, 2004 05:09 PM
