Camber kit + Azenis = AHHHH
Old Nov 24, 2003 | 08:56 AM
the_0ne's Avatar
Default Camber kit + Azenis = AHHHH
Ok, So i bought 205/50/15 Azenis and some Rota 15'' Slips with new ST springs (2.25front / 2.0 rear). I put everything on and my damn Ingall Camber kit (only on front) makes my rims+tires stick out a TON so it rubs on my FENDER. Im thinking about removing the camber kit and get it aligned, but im worried about camber wear.
Should I be fine with no camber kit and a good alignment?
Oh yeah here some pics and I just got GSR seats with my FUGLY blue interior
Old Nov 24, 2003 | 09:04 AM
B_CRUZ!'s Avatar
Default Re: Camber kit + Azenis = AHHHH (the_0ne)
lol... I could of told you that.... remove camber kit and get alighnment. it won't eat the tires fast. trust me.... I had the exact same set up on the exact color hatch with the same wheels and tires...
Old Nov 24, 2003 | 09:10 AM
myhatchrips's Avatar
Default Re: Camber kit + Azenis = AHHHH (B Cruz)
wassup B Cruz. i dont know if you remember me, but i met you while driving along union city blvd awhile back. haha. dont you have a white eg? yea your ride is clean yo. hit me up though. late
Old Nov 24, 2003 | 09:13 AM
B_CRUZ!'s Avatar
Default Re: Camber kit + Azenis = AHHHH (myhatchrips)
yeah that was me... enable your PM and hit me up....
I sold my car but I have a few parts left....
Old Nov 24, 2003 | 09:16 AM
phantom_sol's Avatar
roll fenders? :\
Old Nov 24, 2003 | 09:29 AM
HUBB's Avatar
Default Re: (phantom_sol)
i had 205/50 azenis with 15 in slips and had the same prob. they are like a 215/50...wide as ****. i had camber kit and i rolled my fenders. still rubbed...i said **** it and drove for a while since it wasnt hurtin anything body wise. i ended up selln them for some 195/50 es100....havent looked back since.
Old Nov 24, 2003 | 09:32 AM
Double121's Avatar
Default Re: (HUBB)
my civic did the same thing then I rolled the fenders and it still rubbed...I then took a grinder to the inside lip and removed enough metal to clear the tire, then painted over the metal so it wouldn't rust. No problems since then.
Targa250R's Avatar
be professional
Tell the alignment shop to ignore the camber and have them set the toe to zero.
Improper toe causes more tire wear than improper camber does. Don't worry about your camber. If your toe is set to zero, your tires should wear fairly even.
Old Nov 24, 2003 | 09:52 AM
ruthless013's Avatar
Default Re: Camber kit + Azenis = AHHHH (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Tell the alignment shop to ignore the camber and have them set the toe to zero.
Improper toe causes more tire wear than improper camber does. Don't worry about your camber. If your toe is set to zero, your tires should wear fairly even.</TD></TR></TABLE>
Old Nov 24, 2003 | 09:55 AM
B_CRUZ!'s Avatar
Default Re: Camber kit + Azenis = AHHHH (ruthless013)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruthless013 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>why?
I agree 100% with Targa. I have learned this from experience...
Old Nov 24, 2003 | 10:01 AM
LODOSS's Avatar
lol dude you got Azenis.. either way they'll be gone in a few months.
Old Nov 24, 2003 | 10:05 AM
B_CRUZ!'s Avatar
Default Re: Camber kit + Azenis = AHHHH (LODOSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LODOSS &raquo;</TD></TR><TR><TD CLASS="quote">lol dude you got Azenis.. either way they'll be gone in a few months.</TD></TR></TABLE>if your alignment is ****.
Old Nov 24, 2003 | 10:07 AM
AzG35's Avatar
Toe is the major alignment factor that causes uneven tire wear. Camber plays some role, but toe is much more critical when doing any alignment. You also want some camber anyways for better handling.
Old Nov 24, 2003 | 10:11 AM
nerdsports's Avatar
Default Re: Camber kit + Azenis = AHHHH (AzSi22)
my azenis rub too. my cambers set to zero and my toe is at zero. they only rub on big bumps tho. it doesnt bother me.
targa
Old Nov 24, 2003 | 12:42 PM
the_0ne's Avatar
Thanks man, so here is what im doing, remove my front camber kit and get this done at a shop.
toe - zeo and a alignment should be great
Old Nov 24, 2003 | 12:51 PM
EG2 SiR's Avatar
same thing happened to my bro in laws Ek. It rubbed soooo bad that it cut the tire. We rolled the fenders (thanks to by old little league bat) and all is well.
Old Nov 24, 2003 | 01:06 PM
ransack's Avatar
Default Re: Camber kit + Azenis = AHHHH (EG2 SiR)
take off that camber kit and just get an alignment, the camber wear is not bad at all. The factory camber limit is 1.75 and your not to far over. you can get a good rear camber kit to help.
Old Nov 24, 2003 | 05:57 PM
the_0ne's Avatar
so i remove my kit and set my toe to 0?
Old Nov 24, 2003 | 09:40 PM
while this is all true, it isn't his problem and doesn't answer his question. his tire is rubbing on the fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_one &raquo;</TD></TR><TR><TD CLASS="quote">so i remove my kit and set my toe to 0?</TD></TR></TABLE>
see, he's still not sure.
Old Nov 24, 2003 | 11:32 PM
Nameless RB26's Avatar
Exactly. He needs different tires. That's all there is to it...
Keep the camber kit. Tell the alignment shop about it so they can set the camber if needed though, which is likely. It helps to have one on a lowered car.
Old Nov 25, 2003 | 01:30 AM
sir2k's Avatar
Default Re: Camber kit + Azenis = AHHHH (Nameless EJ6)
I used to have 15" group N with 205/50/15 azenis. Skunk2 camber kit in the front.
they were fine, only the inner fender well plastic piece got scraped down with my old tires.
try more negative camber. I heard that azenis are made with more meat on the inside to anticipate negative camber so they will wear out more even.
Old Nov 25, 2003 | 09:33 AM
HUBB's Avatar
Default Re: Camber kit + Azenis = AHHHH (sir2k)
rubbing is the worst.
Old Nov 25, 2003 | 09:37 AM
scratchy's Avatar
well either way you go you are going to be fucked so pick and chose i would leave the camber on and get it aligned
Old Nov 25, 2003 | 09:49 AM
twinbros's Avatar
the problem is not the camber kit but the tire size. 205 is TOO wide for EG/EK. Get 195 and your problem may go away. Rolling in the fenders will help also.
Peace.
Old Nov 25, 2003 | 10:06 AM
mixxed's Avatar
Default Re: (twinbros)
Azenis and negative camber will not be fun at all....
i give u a few months of daily driving this way until you azenis begin to look like ****.......these tires have a very soft compound and will not withstand negative camber for too long at all....
