H22 in Accord, Picture request, i have a few plugs just hanging around
Old Nov 24, 2003 | 08:32 AM
KTeller8's Avatar
Default H22 in Accord, Picture request, i have a few plugs just hanging around
if anyone has a few pictures of their h22 in their accord, it would be great.
when looking at my motor yesterday, i noticed a plug hanging on the top left hand side, near the fuse box. i have no clue to what this is for. i want to say maybe the cruise control, which i dont have anymore? but not 100% sure,
also if anyone has one of the ride side of the intake manifold, id like to make sure i have my hose and FPR all hooked up properly.
if i had a camera, id show my pics and have you look but i dont.
Old Nov 24, 2003 | 08:57 AM
accordm3's Avatar
do the obvious thing... look at the colors of your wires and go to your wiring diagram
Old Nov 24, 2003 | 08:59 AM
KTeller8's Avatar
Default Re: (accordm3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordm3 &raquo;</TD></TR><TR><TD CLASS="quote">do the obvious thing... look at the colors of your wires and go to your wiring diagram</TD></TR></TABLE>
believe me with over a year in this swap and doing stuff that no one has done before here and there, i ve looked at all the diagrams and such i have..
picture can do a million things.. why i asked
Old Nov 25, 2003 | 01:41 PM
blackcd's Avatar
Did you do an auto ---&gt; 5 spd conversion? If so its just some wires for the automatic set up. I have some wires hanging too, my mechanic told me that they're just some wiring for the auto set up. If their open connectors, tape them up so that they don't get wet.
Old Nov 26, 2003 | 05:07 AM
AccVic's Avatar
Default Re: (KTeller8)
hope this helps a little
Old Nov 26, 2003 | 08:05 AM
KTeller8's Avatar
Default Re: (accordrider)
accordrider thanks and you got pm
anyone else have anything?
Old Nov 26, 2003 | 08:32 AM
accordhybrid's Avatar
The plug on the intake pipe maybe the cruise control plug, which i see you have taken out
the green plug in pic 1 is the second fan switch, the accord has 2 plug while the prelude only has 1
Accordhybrid
Old Nov 26, 2003 | 08:40 AM
KTeller8's Avatar
Default Re: (accordhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid &raquo;</TD></TR><TR><TD CLASS="quote">The plug on the intake pipe maybe the cruise control plug, which i see you have taken out
Accordhybrid</TD></TR></TABLE>
Hey i was wondering.. on my car.. the fan is always on.. from the time i turn the key to when i turn it off?? any way to fix this?
how can i set it up where both fans work?
does this picture look ok? see anything messed up here?
and
Old Nov 26, 2003 | 09:05 AM
t_e's Avatar
t_e
if ur talking about a 4 pin plug that hangs next to the fuse box and wiring harness then ur talking about the cruise control plug.......just tape it up
Old Nov 26, 2003 | 12:31 PM
Old Skool's Avatar
Default Re: (t_e)
Old Nov 26, 2003 | 12:40 PM
Default Re: (Old Skool)
The Green plug that you are referring to make sure that hte plug that you have has a green w/ white chaser and a white wire that is the one that should be plugged in
Accordhybrid
Old Nov 27, 2003 | 07:56 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Skool &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
that wasnt hooked up because it was broke and i was replacing it. its hooked up now!
as far as the green plug, i only found one on my and both fans are running , but they run all the time.. might of been spliced when we did the swap, the guy who helped is in the military and is gone!
Old Nov 27, 2003 | 08:09 AM
KTeller8's Avatar
why did you close loop your sensor valve?
Old Nov 27, 2003 | 09:27 AM
chrisCNL's Avatar
is your cel on for IAT sensor. Also what year accord is it in... and what harness are you using???
Old Nov 27, 2003 | 10:38 AM
KTeller8's Avatar
Default Re: (chrisCNL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL &raquo;</TD></TR><TR><TD CLASS="quote">is your cel on for IAT sensor. Also what year accord is it in... and what harness are you using???</TD></TR></TABLE>
that cel was on, till i replaced the sensor.. now its ok.. i used a 96 ex harness with my swap... 96 lx accord is what i had.
Old Nov 27, 2003 | 02:35 PM
USteppin's Avatar
dont wanna high jack yer thread but i also had some questions..
was looking around the engine bay and found this loose hose, should it be connected to that gold/copper thing?
and this hose off the intake manifold connects to a tube but the tube is connected to nothing, whats up with that? and also that copper thing on the back of the intake manifold, should that be kinked like that?
Old Nov 27, 2003 | 02:54 PM
t_e's Avatar
t_e
Default Re: (USteppin)
usteppin.....the top one on the second pic goes to cruise control , just cap them off...
Old Nov 27, 2003 | 03:12 PM
KTeller8's Avatar
Default Re: (t_e)
that hose you have in yoru hand.. or your talking bout should go to the valve cover and connect on the plug... like this pic.
keep the pics and questions coming! good stuff
Old Nov 27, 2003 | 03:49 PM
USteppin's Avatar
i have a hose conneceted to the pvc already, the loose hose i have is connected to the circle on the right.. no idea what it is
Old Nov 28, 2003 | 04:04 PM
AccVic's Avatar
A couple close ups of my cluster of wires
Old Nov 28, 2003 | 08:06 PM
Nick H's Avatar
New User
alright guys...i have a CEL for IAT and IACV...i tried swapping the two, but still ended up with the same code...any thoughts?
Old Nov 28, 2003 | 10:12 PM
KTeller8's Avatar
Default Re: (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">alright guys...i have a CEL for IAT and IACV...i tried swapping the two, but still ended up with the same code...any thoughts?</TD></TR></TABLE>
how you get the IAT sensor off? on the accord it was screwed in and on the h22 is has two screws.. i cant seem to get those screws off.. seems like i am going to stripe them..
Old Nov 29, 2003 | 02:49 AM
AccVic's Avatar
i had a CEL for the iac forever until i put my ecu in another h22 once i put it back in my car it went away, but then gave me CEL's for the map sensor and egr, so i think my problem is a bad ecu, you might wanna try that
Old Nov 29, 2003 | 06:26 AM
KTeller8's Avatar
just make sure you guys properlly reset the car and system after you mess with these sensors and reset the ecu.. if you fix one CEL, and another pops up.. just go after that problem
also did everyone switch the o2 heater and egr plugs/wire/pins at the ecu?
you should of done that during the swap..
Old Nov 29, 2003 | 07:28 AM
Nick H's Avatar
New User
alraedy did that mike
