Help: Wiring - underdash...
Old Nov 24, 2003 | 07:00 AM
hondahans's Avatar
Default Help me put my R back together!!! (no help in search)
hey guys, my recovered 97 R project is under way and i came across a wiring problem. Due to the fact that the thieves took all my under dash wiring/fuse circuitry, I am left to wonder what am i going to put back in there? is it possible to just find another Integra (maybe Civic?) dash wiring harness of equal obd, or can i go completely obd-1 with all the same stuff? i have access to a 98 LS automatic full under dash junk, but i dont know if it'll work....
If i am able to go obd-1 complete harness (i already have a 95 GSR engine harness and a p28 ecu) will the P28 recognize my ABS system in the same way my ITR ecu would?
And finally, i searched on this but none were exactly the same threads...what year JDM cluster will i need?....i dont have one to switch things from (film or guages) so im stumped. i guess that will all depend on what wiring harness i end up being able to use.....
ANY info on this will help greatly. ....thanks.................... hans->
Old Nov 24, 2003 | 07:08 AM
mstewar's Avatar
Default Re: Help me put my R back together!!! (hondahans)
So you are trying to rewire totally odb-1?
I would assume that any equivalent year's integra under dash harnesses would work.. going between odb-1 and 2 gets a little shakey for me..
Old Nov 24, 2003 | 07:13 AM
hondahans's Avatar
Default Re: Help me put my R back together!!! (mstewar)
Mark, I'm not exactly trying to rewire to obd-1, just looking for the easiest way to HAVE wiring...whatever it takes.
Congrats on the new R re-purchase....I guess yours was a little more complete huh?
Old Nov 24, 2003 | 07:59 AM
bgod's Avatar
i have a complete 99 integra ls manual parts car that i need some parts from. still have the complete underdash harness leading upto the ecu if you're interested.
wiring would be the same, all you would need to do is add the wires for the vtec system to engage.
Old Nov 24, 2003 | 08:51 AM
chad's Avatar
Moderator
Default Re: Help me put my R back together!!! (bgod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgod &raquo;</TD></TR><TR><TD CLASS="quote">i have a complete 99 integra ls manual parts car that i need some parts from. still have the complete underdash harness leading upto the ecu if you're interested.
wiring would be the same, all you would need to do is add the wires for the vtec system to engage.</TD></TR></TABLE>
this route would probably be the easiest and cheapest....
Old Nov 24, 2003 | 09:19 AM
hondahans's Avatar
Default Re: Help me put my R back together!!! (chad)
thanks for the info, as far as the other questions....what cluster? obd-1 or 2 ITR? does anyone know about the ABS? thanks, keep it coming.........
Old Nov 24, 2003 | 09:26 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahans &raquo;</TD></TR><TR><TD CLASS="quote">Mark, I'm not exactly trying to rewire to obd-1, just looking for the easiest way to HAVE wiring...whatever it takes.
Congrats on the new R re-purchase....I guess yours was a little more complete huh? </TD></TR></TABLE>
ah.. gotcha.. I don't think the cluster will matter between OBD1 and OBD2.. not 100% sure, but i can't think of anything that would be dependant on one or the other..
yeah, i think my R came a little more complete than yours.. still cool either way though! good luck!
Old Nov 24, 2003 | 09:36 AM
hondahans's Avatar
I just called Hasport and threw my dillema at them. they said that it would not matter if i use an LS harness, they also added that i can go all obd-1, just to worry about smog legalities. ABS will have no ill effects regardless of which way i go. thanks again for all who posted................... hans-&gt;
Old Nov 24, 2003 | 10:20 AM
done's Avatar
why not get a standalone harness?
Old Nov 24, 2003 | 10:23 AM
hondahans's Avatar
Default Re: Help me put my R back together!!! (Jordo)
A full stand alone? im not sure how that would work, you see I have zero wiring harness under the dash. so if i understand what you mean...create a whole new one?
Old Nov 24, 2003 | 04:08 PM
typesfanatik's Avatar
hey hans its Joe with the rsx you never called on sunday to go to the track how did you guys do. ( i didnt get up til 10 and i realized you never holla's)
hit me up here or club rsx
Modified by typesfanatik at 8:26 PM 11/24/2003
Old Nov 24, 2003 | 06:32 PM
hondahans's Avatar
Default Re: Help me put my R back together!!! (typesfanatik)
yo dude, same here i woke up sooo late and missed everyomes call. chad ran a 11.993 though!! haha too funny we slept in...late nights will do that..
Old Nov 24, 2003 | 06:47 PM
no foolin i stayed at the staircase until 3 am then came home set my alarm and for some reason turned it off. i was looking forward to running to ohwel.
11.9 not too bad
Adeeb1395
Jul 31, 2017 06:18 PM
Hoock 90
Jul 20, 2010 12:57 PM
therotaryrocket
Jul 12, 2009 09:54 AM
jdmkid_82
May 27, 2006 12:38 PM
Leisyman
Mar 31, 2002 07:33 AM
