crossthreaded bolt holes on block!
Old Nov 24, 2003 | 02:31 AM
93preludes's Avatar
Default crossthreaded bolt holes on block!
Hey guys, i need some help.. i've got some crossthreaded transmission bolt holes on the block and i need to get this thing up to the block and bolted down, how can i get this thing rethreaded or get a bolt in there somehow? thanks please reply!!
Old Nov 24, 2003 | 06:13 AM
kpt4321's Avatar
Re-Tap the bolt holes and hope the threads aren't too done.
Old Nov 24, 2003 | 06:32 AM
JimBlake's Avatar
Default Re: (kpt4321)
If a couple bolt holes next to each other are bad, I'd probably want to use HeliCoils or TimeSerts to repair them. If you chase the holes out with a tap, then carefully put the bolts in, make sure they hold the proper torque. After a couple hot/cold cycles check they haven't come loose. If they've come loose, then you gotta go back & fix them. Then you probably need to pull the tranny again.
Old Nov 24, 2003 | 12:24 PM
kpt4321's Avatar
Yeah, that is very likely the right thing to do. If they look iffy at all, helicoil them.
Old Nov 25, 2003 | 09:33 AM
doublejz's Avatar
OMG YOU HAVE TO JUNK YOUR ENGINE NOW!!!!, j/k yea just retap them, I have done it not really a big deal
Old Nov 25, 2003 | 11:20 AM
93preludes's Avatar
Default Re: (doublejz)
i'm going to buy the threading kit here pretty soon to do it.. hopefully they're ok, they dont seem horribly bad but just keep spinnin whenever they seem to grab hold.. so yeah, i'm hoping everything turns out ok.. i'm going to practice on a spare block just to make sure.. is 12x1.25 a common bolt size/thread pitch? hoping it comes with the kit..
Old Dec 4, 2003 | 01:58 PM
93preludes's Avatar
Default Re: (93preludes)
well unfortunately when i pulled the tranny again, i noticed that I lost the first two threads in the bolt hole... I am having trouble lining up the mainshaft teeth and clutch which is making it difficult for the bolts to catch thread as they're too short... now i'm after a 3.5" 12x1.25mm bolt :-/... crap... any advice
jorge59la
Jun 18, 2008 02:57 PM
Homotor
Apr 20, 2007 02:11 PM
allmotorb18c14door
Welding / Fabrication
Mar 2, 2007 12:04 PM
The Internet Tough Guy
13
May 17, 2006 07:18 PM
GSRCRXsi
12
Dec 2, 2004 07:30 PM
