Running S2k Pistons on h22 motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego »</TD></TR><TR><TD CLASS="quote">Has any of you guys personally done it? And whats needed to make it work on a closed deck h22. It raises your comp to 12:1 right? </TD></TR></TABLE>
type S pistons and mill the head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">i was going to but the cost is too high on those pistons. they are like 140 bux each. </TD></TR></TABLE>
I wanna keep the sleeves OEM because of reliability issues, thats why i want to run s2k pistons. I just wanted to know if its been done before. And if i could hear your accounts on going this route.
no, from what ive read because of the wrist pin location the s2k, the piston will sit lower in the cylinder producing lower compression.
just go with the type s, small overbore, thin headgasket, and if you want more mill the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego »</TD></TR><TR><TD CLASS="quote">But no one on this board can say anything from personal experience? </TD></TR></TABLE>
the idea has been kicked around, but like stated above the wrist pins location makes it less feasible than using type s pistons and milling the head or using a thinner headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>It sure has right here https://honda-tech.com/zero...&page=
Yea, i know its been thrown around alot but i was wondering if any of YOU guys have done it personally so i can see the end results. And about running weiscos on the stock sleeves, i wouldnt try that either. Too damn risky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">if wiseco made an off the shelf psiton in a bore i could use i would be running them in my next engine. but since they only make 87, 88 and 89 mm bores i am SOL with stock sleeves.</TD></TR></TABLE>Umm 87mm is stock bore.
SO yeah, the reason none of us have any experience in doing it is because there is no point, there are cheaper/easier/more readily avaible alternatives do doing what the s2k pistons accomplish......... thats why no one is doing it... and who told you stock sleeves are reliable? and yes....... 87mm is stock bore
Well i just took it upon myself to think this since most of the b series boys tell me that going oem sleeved with civic R pistons is more reliable then resleeved block running after market pistons. Or so says Rocket.
the s2000 uses the same frm that the h series does,. it has a 87 bore, and what honda did was find a way to make forged pistons work with frm. neway here some math
compression height (distance from pin to top of piston)
H22 piston is 1.220
H23 piston is 1.204
S2000 piston 1.178
using c-speedracing.com with a piston dome cc of 11.07cc
with the s2k piston it would sit .042 mm lower than the stock h22 piston in the bore. and would yeild a 10.52:1 compression ratio
with the s2k piston it would sit .026 mm lower than the stock h23 pistonin the hole. and would yeild a 12.23:1 compression ratio
if you guys have any question feel free to ask
H22 piston is 1.220
H23 piston is 1.204
S2000 piston 1.178
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kentucky accord »</TD></TR><TR><TD CLASS="quote">comparing a stock B series sleeve to a stock H series sleeve is like comparing my interior to a caddy. 2 different worlds......</TD></TR></TABLE>Agreed it's all about FRM. B series don't have this problem.
i am actually more excited about the 2004 s2k pistons they are even lower compresion., and may be worth while looking at for boost option, stock forged pistons with frm,
