CEL keeps coming on..
Old Nov 23, 2003 | 08:55 PM
JDMlyfestyle's Avatar
Default CEL keeps coming on..
I just recently installed a Fields Vtec controller. wired up everything right. vtec kicks in at 5200. eveyrthing works fine. But if i hit vtec in 4th or 5th the CEL comes on for a code 21. Vtec spool solenoid i believe. but if i shut my car off and turn it back on the CEL goes back off. Y is this happening?
Old Nov 23, 2003 | 10:22 PM
Shawn C's Avatar
In The Garage
i take it this is in the 92 cx w/ b16 block/itr head... what ecu are you running? P28? stock or chipped? have you triple-checked the wiring?
Old Nov 23, 2003 | 10:32 PM
Dancing is Forbidden's Avatar
Default Re: (ShadyEH2)
it didnt do this before you did the install? recheck yourself man!
Old Nov 24, 2003 | 04:48 PM
Checked all the wiring.. all connections are made and very secure. everything is electric taped to prevent them from touching each other. Im running a Chipped P28
battleREADYb20
Mar 22, 2008 11:33 PM
zccr-xsi
Feb 17, 2008 04:35 AM
92jdmhatch
Nov 19, 2006 11:29 PM
92jdmhatch
Nov 19, 2006 01:27 PM
Forrest Gump 9
Aug 11, 2003 05:26 PM
