Who here has hit 200whp with their Skunk2 Stage 1's?
Since I have Stage 1's on my R, who here has hit 200whp or semi close with them. What extensive mods have u done? tuning time hours? I know every motor is different but just want to know what to expect...
thnx
thnx
Someone did it with a stock bottom end,i think they had a 00 ITR i cant rember the guys name...
My old roomate did it too search RainmanEK
user name was MPH he hit over 200whp with the skunk stage ones, but i believe he no longer has his ITR, i think he sold it for either a STI or a EVO ( if i remember correctly)
Im close to 200, (199.6/132.6).
I tuned at Dsr for 1.5 hours, then got Dtr's header and baseline at those numbers above. I will go back to Dsr (or try Dynolabs) if I get new cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itR484 »</TD></TR><TR><TD CLASS="quote">user name was MPH he hit over 200whp with the skunk stage ones, but i believe he no longer has his ITR, i think he sold it for either a STI or a EVO ( if i remember correctly) </TD></TR></TABLE>
MPH that is the guy i was thinking of
I did in my old EG. You can see dyno plots in my signature. PnP'ed head, stage 1's, SMS header, full 2.5" exhaust, and stock bottom end. Ans yes, Lawrence tuned it. 201/132.
thats nice to hear, but for me, I got my stage 1 tuned with Hondata, P&P head, 3 angle valve job, deck the head 20 thou, DC JDM header, 2.5 exhust, cam gears, ARC intake arm........I jsut got over 180 whp wiht 125 ft/lbs of trq, kinda low if you ask me, but I tried everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lePetitePrince »</TD></TR><TR><TD CLASS="quote">thats nice to hear, but for me, I got my stage 1 tuned with Hondata, P&P head, 3 angle valve job, deck the head 20 thou, DC JDM header, 2.5 exhust, cam gears, ARC intake arm........I jsut got over 180 whp wiht 125 ft/lbs of trq, kinda low if you ask me, but I tried everything. </TD></TR></TABLE>
ur #'s seem low
ur #'s seem low
Those figures sound realistic to me. What was the specs of the bottom end and head? Who did the p&p?
It's your header. That was my weak point until I got my SMS. I made 20whp over the DC JDM 4-1. Yes you read that right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez »</TD></TR><TR><TD CLASS="quote">Just a thought, aren't Skunk2-Stage1 similar to 2001 OEM ITR cams ?? </TD></TR></TABLE>
Nope...the primary and secondary lobes may be similar to the OEM itr cams, but the vtec lobes are definately different.
Austin
Austin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridhatch18 »</TD></TR><TR><TD CLASS="quote">did you guyz change your timing belt when you did the cam swap or did you reuse your old one?</TD></TR></TABLE>
i used the same old one
JunIntegra
43
Mar 4, 2004 04:41 PM
TheTruth709
13
Feb 20, 2004 12:59 AM
