Tilton Carbon/Carbon Clutch
Old Nov 23, 2003 | 03:42 PM
SpeedDreamz.com's Avatar
Default Tilton Carbon/Carbon Clutch
ANyone had any experience with the Tilton c/c clutch assembly? What did you think? Where is a great place to get one?
Old Nov 23, 2003 | 03:49 PM
bambooluv's Avatar
Default Re: Tilton Carbon/Carbon Clutch (30psiCiv)
What do you want to know about it? Im pretty sure all the feedback that your gonna get on it is good. As far as were tog et them, drop tony1 a line i know he can locate one for you.-pdang
Old Nov 23, 2003 | 03:53 PM
Default Re: Tilton Carbon/Carbon Clutch (bambooluv)
Have you used one? What do you think?
Old Nov 23, 2003 | 04:10 PM
boostedh22a's Avatar
I have one, and it was the best money I ever spent on the car
Old Nov 23, 2003 | 05:54 PM
Rboosted717's Avatar
great clutch, plan on spending around $3100-3400 (pending tax) for it.
Also its high maintanance because you have to check the pressure plates and surface of the clutch disc all the time.
Old Nov 23, 2003 | 06:43 PM
ihaterice's Avatar
Default Re: Tilton Carbon/Carbon Clutch (Rboosted717)
email me at james@titanmotorsports.com and i can get you a good deal on the carbon/carbon tilton
Old Nov 23, 2003 | 07:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rboosted717 &raquo;</TD></TR><TR><TD CLASS="quote">great clutch, plan on spending around $3100-3400 (pending tax) for it.
Also its high maintanance because you have to check the pressure plates and surface of the clutch disc all the time. </TD></TR></TABLE>
How often are you talking about? Clutches need normal inspection anyway, do these require more?
Old Nov 23, 2003 | 07:18 PM
yes these require ALOT more work.
Tilton provides measuring devices and gauges to check the wear with the purchase of the clutch. Tilton and most people who use the clutch suggest checking the clutch after every race or testing session. For street use I would suggest checking the clutch with every oil change. The clutch will last for a long time if you keep checking the cluches and keep up with rotating the plates and disc.
Old Nov 23, 2003 | 11:02 PM
I have raced an entire season, and a few races last year, and haven't had to change plates yet......Great piece..........no maintenance
Old Nov 24, 2003 | 04:38 AM
Default Re: (boostedh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">I have raced an entire season, and a few races last year, and haven't had to change plates yet......Great piece..........no maintenance</TD></TR></TABLE>
How often do you inspect it?
Old Nov 24, 2003 | 05:27 AM
tony1's Avatar
Default Re: (30psiCiv)
You can easily go all year w/o checking a tilton carbon. The cerametallic ones wear ALOT quicker and do require periodical maintainance, but don't worry about the carbon. It's the best and last clutch you'll ever buy!
Old Nov 24, 2003 | 11:50 AM
I haven't yet
Old Nov 24, 2003 | 07:36 PM
2K_TEG's Avatar
if you are going to plunk down the cash, get one of the new hydraulic tranny setups too.
The carbon, carbon will last forever, but is over twice as much as the cerametallic. If you have the $ go for it.
Kyle
Old Nov 25, 2003 | 03:19 AM
turbologist's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You can easily go all year w/o checking a tilton carbon. The cerametallic ones wear ALOT quicker and do require periodical maintainance, but don't worry about the carbon. It's the best and last clutch you'll ever buy!</TD></TR></TABLE>
Would you expect the cerametallic to out last the single disk clutches? being that they are both put through the same abuse? Just wanna gauge if its worth the money from a length of life standpoint...
How exactly does the Tilton Hydraulic Release Bearing Kits work and how does it help?
Old Nov 25, 2003 | 05:28 AM
tony1's Avatar
Default Re: (Turbologist)
I would expect the dual cerametallic clutch to last longer than any single disk that can hold that same amount of power. The good thing about the tilton is that you can just buy replacement disks. I think the disks are only like $150 each. So, it's easily rebuildable when it does wear out.
Old Nov 25, 2003 | 07:26 AM
Default Re: (tony1)
Thnx....how bout the 2nd part of the question?
"How exactly does the Tilton Hydraulic Release Bearing Kits work and how does it help? "
Old Nov 25, 2003 | 07:51 AM
2K_TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbologist &raquo;</TD></TR><TR><TD CLASS="quote">Thnx....how bout the 2nd part of the question?
"How exactly does the Tilton Hydraulic Release Bearing Kits work and how does it help? "</TD></TR></TABLE>
I answered your IM.
The HRB replaces the stock master cylinder, slave cylinder, fork and bearing. It reduces the mechanical parts involved so it give you quicker shifting and a better feel.
Old Nov 25, 2003 | 08:50 AM
saso
Guest
Posts: n/a
I use the CC. Best thing since slice bread. Dont look for too much clutch slip though.
Old Nov 25, 2003 | 09:23 AM
Default Re: (2K_TEG)
Gotcha...thnx
kungfuSiR
Nov 7, 2014 06:27 AM
ghettoracer
Feb 23, 2005 06:53 PM
earl
Sep 10, 2004 01:36 PM
quicksol95
Mar 24, 2004 05:29 PM
