all you racers out there, how fast would my accord be ??
Old Nov 23, 2003 | 03:00 PM
steph_accord's Avatar
Default all you racers out there, how fast would my accord be ??
Hi, i'm going to put an h22a motor in my 1988 honda accord 4 door. I would like to know how fast my car would be with that motor, i'm not going to modify anything else, it will be the h22a engine, an air intake, and an exhaust system, thats it. I'd like to have an approximation of what i could do on the 1/4 mile, and from 0 to 100 .... And by the way, at what rpm does the h22a tops off at ? is it 7,5 rpm ?? thats not 8 rpm , but it's still awesome....
Old Nov 23, 2003 | 04:42 PM
Simple's Avatar
Default Re: all you racers out there, how fast would my accord be ?? (steph_accord)
bench racing is no fun, find out for urself. 1/4 mile times depend upon the driver, tuning of the engine, modifications, etc. just swap it and see.
Old Nov 23, 2003 | 06:27 PM
f22a's Avatar
Default Re: all you racers out there, how fast would my accord be ?? (Simple)
about the same times that an h22a integra will run, but you're going to have one hell of a time getting that motor in there
Old Nov 23, 2003 | 07:21 PM
Crono139's Avatar
You'll run the same times as a stock Prelude (with an H22, not F22). Relatively the same weight. So estimating around high 15s, or so.
Ah, almost forgot. Is your car an automatic, or manual?
Old Nov 24, 2003 | 05:50 AM
f22a's Avatar
Default Re: all you racers out there, how fast would my accord be ?? (Crono139)
since when did stock preludes run high 15s?
also, you guys are missing the point that unless this kid has a ton of cash at his disposal, the h22a will not be going in his 3rd gen accord.
Old Nov 25, 2003 | 12:27 PM
Crono139's Avatar
Default Re: all you racers out there, how fast would my accord be ?? (f22a)
I don't see why high 15s is unachievable in a 3G Accord with an H22. I know of a number of 5Gs that run mid 14s with the H22, and bolt-ons, and they are heavier than the 3Gs.
Old Nov 25, 2003 | 12:46 PM
Mike813's Avatar
with that $ your going to spend on that 88 accord, why not buy a 94 body prelude and save urself the troubles??
Old Nov 25, 2003 | 02:10 PM
RotaryBzzzz's Avatar
Default Re: all you racers out there, how fast would my accord be ?? (Mike813)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 &raquo;</TD></TR><TR><TD CLASS="quote">with that $ your going to spend on that 88 accord, why not buy a 94 body prelude and save urself the troubles?? </TD></TR></TABLE>
kinda what i was thinking...
Yes, you already have the car...you probably love it...but that's a hella lot of fabrication. The reality of this conversion is that your car will be laid up for a LOOOOOOOOG time and you will spend 2-3x more $$ than you planned. Is it worth it?
Old Nov 25, 2003 | 03:57 PM
LookingForVTEC's Avatar
Good luck trying to get that motor into a 1988 accord. Save youself the trouble, get a 90 accord.
Old Nov 25, 2003 | 03:59 PM
whoa its len 2's Avatar
Default Re: all you racers out there, how fast would my accord be ?? (LookingForVTEC)
B20 fits in a 3geez.
Old Nov 25, 2003 | 08:18 PM
stickercuttingcom's Avatar
Good luck on that one!
Try this link to see just how EASY it is
http://www.geocities.com/rick_spiff/car/index.html
Nate.
Old Nov 26, 2003 | 07:33 AM
v4lu3s's Avatar
RTFM
a stock prelude with an h22a will lrun as well as a high 14 with a great driver, 14.9-15.3 is a good range, with the 5th gens running slightly slower.
and the weighth of the prelude is about 300 or mroe lbs heavier than a 3rd gen accord. a 3rd gen accord is in the 2300-2500 lb range. thats civic territory, hell a teg gsr is closer to 2700 as well.
a 3rd gen accord with an h22a shouold be capable of low 14s, but the hard part is getting the engine in and working.
otacon122
Oct 28, 2008 05:13 PM
wish_i_was_h22a
Aug 26, 2005 01:43 PM
ZexyAccord
Jan 27, 2005 07:16 PM
95accordh22a
Nov 22, 2004 02:38 PM
drSquish
Nov 3, 2004 09:56 AM
