1/4 times are in!!!
ok guys i hit the track to day in my 96 ex coupe! Car has b18c5: intake and suspension work. Stock 14in wheels and tires, constructive critism more than welcome.
reaction time 0.6832
60 ft 2.3272
1/8 mile 9.7123
1/4 mile 14.8643 @ 97.2952mph
i only got one run so i think i could def pull the car down to a 14.6-14.7 w/ a lil better 60ft
60 ft 2.3272
1/8 mile 9.7123
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">yeh but the factory header, and civic cat and exhaust is really choking me</TD></TR></TABLE>
True, new exhaust, heaser, high flow cat and some drag radials you might get a 13.9
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">yeh?? what kinda of time should i be runnin w/ a 97-98mph et?? You think a 2.1 60ft is possible for me</TD></TR></TABLE>
w/ a crappy 2.2 60' time I hit 14.2@98, I've seen people cut 2.0/2.1 60' foot times and run 13.9 at 99 mph. So if you can get better tires and 60' times you can hit low 14's definately, and maybe if your lucky and one hell of a driver, break 13's.
as your 60' times go down, so will your mph. if you were to pull a 2.1 your trap speed would have only been around 94-95. you have potential to run low 14's as it sits with better 60's.
i pulled 14.0's@96 mph with 2.10 60's on azenis's. good luck next time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh »</TD></TR><TR><TD CLASS="quote">you should be runnin better than that</TD></TR></TABLE>
No high 14s is good.
My EG w/ B18c5 and full suspension does a 4 year 60 ft.
and a 10 years 1/4 mile.
Guest
Posts: n/a
nto bad i went to the 1/4 myself for the 1st time
Reaction .919
60 ft 2.321
1/8 mile 9.7 @ 72.90
1/4 mile 14.9 @ 90.72
99 Civic Si full interior B16 with I/H/E
Would have been better if I didn't blow my differential on my 3rd run.
Reaction .919
60 ft 2.321
yeh but like i said i only got one run and only had the car for a 2 weeks, i came froma 240sx. big change driving a FWD, but ill have it down pat by spring time whne track re open. i will be loookin for high 13's
