Skunk2 H22 buildup questions
Old Nov 23, 2003 | 10:52 AM
explosive's Avatar
Default Skunk2 H22 buildup questions
OK...I am definitely going to go with a Skunk2 stage II buildup within the next couple of months, but I just have a couple questions. First, I am thinking that I should get the Stage II camshafts, stock size valves, their springs and retainers, and I already have the cam gears.
BUT, the question I have is about the valves, should I go with the standard or the high compression valves?
Also, do I NEED to have an aftermarket header with this setup?
Old Nov 23, 2003 | 12:23 PM
Stylin-Honda's Avatar
Default Re: Skunk2 H22 buildup questions (explosive)
If you're going N/A you might as well go with the high compression valves to give you a little more top end power (every bit counts right?). My buddy hooked up the whole Skunk2 package on his B16 (using the high compression valves as well as a thinner head gasket) and it made a big difference... it pulls like crazy up top. Hope this helps.
Old Nov 23, 2003 | 12:27 PM
Anhjockz's Avatar
hey let me know about the pull atfer you install this whole setup cause iam about to it in a few months.....so yeah i would like to know the same questions your asking too thanks guys in advance
Daboi630's Avatar
you dont *need* an aftermarket header.
**** you dont even *need* aftermarket cams
but i say get a REAL aftermarket header.
i think i heard Dave @ SMSP gonna do another run soon
Old Nov 23, 2003 | 11:01 PM
satan_srv's Avatar
Default Re: Skunk2 H22 buildup questions (Daboi630)
if you're actually building I am thinking you are sleeving and buying pistons. If so forget about H comp valves and just buy the right pistons.
If you're not sleeving and buying pistons I would say your compression will never be high enough to make good power with stage 2s
Old Nov 23, 2003 | 11:02 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explosive &raquo;</TD></TR><TR><TD CLASS="quote">]Also, do I NEED to have an aftermarket header with this setup?</TD></TR></TABLE>
You're kidding yourself if you think a stock header is going to flow enough for the cams. If you want to make not much power..sure a wild cam and a stock header is the way to go
Old Nov 23, 2003 | 11:16 PM
black_bb1's Avatar
Default Re: Skunk2 H22 buildup questions (satan_srv)
Would the jdm header have good enough flow to accomodate a mild n/a cam?
Old Nov 24, 2003 | 05:23 AM
explosive's Avatar
I have the JDM header, but what Satan_SRV said is what I was thinking, I am going to definitely have to upgrade the header or else I won't have enough flow.
As for the sleeving and the pistons, the shop that I have been talking to about this says that I don't need to really build the bottom end at this point, that it would be best to just use a thinner head gasket, get the high compression valves and the stage 2 stuff.
They say that that alone will do what I need.
Old Nov 24, 2003 | 07:56 AM
v4lu3s's Avatar
RTFM
whatever you do dont "upgade" to a DC sports header...they have smaller primaries than the OEM JDM header...
Old Nov 24, 2003 | 08:04 AM
BolivianFuego's Avatar
Default Re: (explosive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explosive &raquo;</TD></TR><TR><TD CLASS="quote">I have the JDM header, but what Satan_SRV said is what I was thinking, I am going to definitely have to upgrade the header or else I won't have enough flow.
They say that that alone will do what I need.</TD></TR></TABLE>
That would be half assing it. If you want the most outta those cams you gotta accomedate em with some nice pistons, maybe bump up the comp. to 12:1 or a lilttle bit higher. Those would compliment the cams nicely.
Old Nov 24, 2003 | 08:21 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">If you're not sleeving and buying pistons I would say your compression will never be high enough to make good power with stage 2s</TD></TR></TABLE>
i wouldnt say that... eddie made right at 200whp with skank2 stage 2's, and that was with the stock jdm header
Modified by JDogg at 8:21 PM 11/24/2003
Old Nov 24, 2003 | 09:39 AM
SKDRCR's Avatar
Default Re: Skunk2 H22 buildup questions (black_bb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_bb1 &raquo;</TD></TR><TR><TD CLASS="quote">Would the jdm header have good enough flow to accomodate a mild n/a cam?</TD></TR></TABLE>
No
redhanyo
12
Apr 15, 2006 07:39 PM
CivicSiDriver02
Mar 1, 2006 07:43 PM
jdmlude_dude
Jul 20, 2005 10:16 PM
explosive
Nov 29, 2003 08:35 AM
