: ( broken belt, piston to valve contact, shitty idle, bad compression in #3....help
Old Nov 23, 2003 | 08:36 AM
optoomistic's Avatar
Default : ( broken belt, piston to valve contact, shitty idle, bad compression in #3....help
b18b 170 K
i can see a scratch on the piston top.. how can i find out if the piston needs to be replaced...it runs like **** now.... im wondering if i can fix/replace the head...or if i should/need to build the bottom end too.? or if i should start shopping for a new motor...(im poor)
this is the second time my timing belt has broken...
the first time i was lucky and the belt was replaced...(but not the water pump)
then the pump siezed and snap....smack bend..im fu cked
i was hoping to be able to upgrade my valve train and port my head.. and upgrade but after replacing the belt and finding out i had a LARGE problem
ive been in limbo....
of course everyone and there cousin has been like "slap" a vtec head on it YO! it would be faster than a gsr...
IS THERE A WAY TO BIULD A RELIABLE LS VTEC?
without building the bottom end
so thats turned out to be a bit of a compund question...but i have a compund problem .....guide me hondatech junkies and tech alike
dan
Old Nov 23, 2003 | 09:05 AM
Hites
Guest
Posts: n/a
Default Re: : ( broken belt, piston to valve contact, shitty idle, bad compression in #3....help (optoomist
your best option: click the first line of my sig
bmxking192
Aug 31, 2011 08:20 AM
mrspeedy69
Jul 20, 2009 06:51 AM
brunorahl
Jun 4, 2006 06:52 PM
ncnative
Jan 14, 2005 06:39 AM
JSPECEX
11
Mar 28, 2003 07:59 AM
