H22 EG SPRING ISSUE!!!
Old Nov 23, 2003 | 08:26 AM
C M S's Avatar
Default H22 EG SPRING ISSUE!!!
What is a good affordable coil-over setup for a 92 hatch w/ a h22? I am considering a Skunk 2 set-up. Do I need integra springs up front, will they fit? Please help!!! THANKS....
Old Nov 23, 2003 | 08:28 AM
Kamin's Avatar
Default Re: H22 EG SPRING ISSUE!!! (1SICJDM)
civic springs are fine, ground control coilovers and KYB or Koni shocks are a great setup.
Old Nov 23, 2003 | 08:36 AM
C M S's Avatar
Default Re: H22 EG SPRING ISSUE!!! (Kamin)
I heard civic spring rates are too low, causing horrible understeer and botoming out. What gives????
Old Nov 23, 2003 | 08:39 AM
Kamin's Avatar
one of the stupid rumors that was started long before the h22 swap was popular.
Old Nov 23, 2003 | 09:01 AM
aeolus's Avatar
im using the skunkworks integra coil overs with koni shocks,its a decent ride considering i have es polyurethane bushings.Handling is better to me than it was with the stock motor.
Old Nov 23, 2003 | 06:39 PM
C M S's Avatar
Default Re: H22 EG SPRING ISSUE!!! (aeolus)
Are the integra coil-overs a direct bolt in?
Old Nov 23, 2003 | 08:05 PM
PHiZ's Avatar
The h22 is 200 lbs heavier than the d-series engine, I dont' know if my math is right, but would you increse the springs my 200lbs to compensate??
-PHiZ
H22EG'z
Suspension & Brakes
May 29, 2009 03:44 PM
SpeedingHatch
Feb 9, 2004 01:03 PM
C M S
Feb 8, 2004 10:36 AM
c1civic
Jan 7, 2004 01:02 PM
prjctCIVIC
Jan 30, 2002 04:26 AM
