How long have you been boosting on Eagle rods?
Old Nov 23, 2003 | 05:13 AM
Boostage's Avatar
Default How long have you been boosting on Eagle rods?
how much hp? what RPMS? and what motor?
Old Nov 23, 2003 | 08:47 AM
2K_TEG's Avatar
Default Re: How long have you been boosting on Eagle rods? (Ateyour2JZ)
high 300, low 400.
8k RPM
2L B18B
Eagle rods for over a year.
I think flamenco-T has the same setup too but B18C and a little longer than I have had mine. His even survived theft by a crazy ricer.
Old Nov 23, 2003 | 08:52 AM
99B16Si's Avatar
low to mid 300whp. ls/vtec w/ 8500 rev limiter.
no problems
Old Nov 23, 2003 | 11:44 AM
XXXRacing's Avatar
Default Re: (99B16Si)
Eagle Rods in my motor. Has seen 26 psi since may, before that was running 10-20 lbs for 8 months. Car makes approximately 500 whp. Brian
Old Nov 23, 2003 | 11:53 AM
Burke's Avatar
Banned
Default Re: (XXXRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing &raquo;</TD></TR><TR><TD CLASS="quote">Eagle Rods in my motor. Has seen 26 psi since may, before that was running 10-20 lbs for 8 months. Car makes approximately 500 whp. Brian</TD></TR></TABLE>
which rods????
Old Nov 23, 2003 | 12:15 PM
XXXRacing's Avatar
Default Re: (Burke)
they were purchased about 2 years ago. I do not think they have the upgraded rod bolts. Been revving to 10K every weekend too.
Old Nov 23, 2003 | 12:53 PM
TurboR1391's Avatar
Default Re:
I've been using the same eagle rods for 15k miles. Ran 18psi quite a few times no problems. *Vonte' knocks on wood*
Old Nov 24, 2003 | 07:53 AM
Burke's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing &raquo;</TD></TR><TR><TD CLASS="quote">they were purchased about 2 years ago. I do not think they have the upgraded rod bolts. Been revving to 10K every weekend too. </TD></TR></TABLE>
cool
i am contemplating getting some eagles. but everyone says they only handle like 400hp max. and i want 400hp min.
Old Nov 24, 2003 | 08:04 AM
Tinker219's Avatar
Default Re: (Burke)
they will be fine. somebody started a "bash eagle" thread, and well, ya. You will be fine w/the Eagles
Old Nov 24, 2003 | 08:07 AM
30psi Teg's Avatar
Default Re: (Tinker219)
my eagles have held strong for 6000 miles boosted at 15psi and are now holding strong at 30~32psi in my new setup
Old Nov 24, 2003 | 09:29 AM
15psi of fun's Avatar
Default Re: (30psi Teg)
6000miles on 15psi no problem. I’m putting new barring in right now because my oil pump blow up and I'm a little worried about torqueing the bolts down this will be the 3rd time do i need to over torque them a little bit or use the same torque spec.
Old Nov 24, 2003 | 11:33 AM
MrCrx's Avatar
Eagle rods with normal arps. 400whp, 8100 rpms, big bore type r.
Old Nov 24, 2003 | 03:39 PM
karmannghia's Avatar
Eagle rods from importparts.com for 6 months now...Constant beatings every Friday at the track and on the street when the weather permits....Hot down here in Georgia.
I know of 2 others that make over 400 whp and going on close to 6 months...
Old Nov 24, 2003 | 04:10 PM
Ben Huynh's Avatar
Default Re: How long have you been boosting on Eagle rods? (karmannghia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by karmannghia &raquo;</TD></TR><TR><TD CLASS="quote">Eagle rods from importparts.com for 6 months now...Constant beatings every Friday at the track and on the street when the weather permits....Hot down here in Georgia.
I know of 2 others that make over 400 whp and going on close to 6 months...</TD></TR></TABLE>
Old Nov 24, 2003 | 04:23 PM
Rhman19's Avatar
Even started with no oil. A guy from eagle posted one time on here that out of 900 rods sold last year, only 4 failures. And that was due to over or under tightening. Sometimes the internet can blow things out of proportion.
Old Nov 24, 2003 | 04:25 PM
Jared's Avatar
Default Re: (Rhman19)
Eagle H beams here with stock rod bolts. 20psi almost daily and twice a week at the track. B18C1 w/ an 8500 rev limiter.
Old Nov 24, 2003 | 04:32 PM
BlueSi2k's Avatar
Default Re: (Jared)
Only about 5k at 8psi but no problems. Everyone just jumped on the hate eagle bandwagon.
Old Nov 24, 2003 | 04:47 PM
AVATAR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhman19 &raquo;</TD></TR><TR><TD CLASS="quote"> A guy from eagle posted one time on here that out of 900 rods sold last year, only 4 failures. And that was due to over or under tightening.</TD></TR></TABLE>
Anyone know what the torque spec is one the Eagles?
Old Nov 24, 2003 | 04:48 PM
BlueSi2k's Avatar
Default Re: (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone know what the torque spec is one the Eagles?</TD></TR></TABLE>
If I remember correctly mine were 28ft-lbs
Old Nov 24, 2003 | 04:58 PM
Cyber ITR's Avatar
Default Re: (BlueSi2k)
damn it
i cant make up my mind , whether i should buy the upgraded bolts for my eagle or not
im basically just building a dyno queen 500-550whp somewhere around there
Old Nov 24, 2003 | 05:11 PM
2ltrsnailpwr's Avatar
Default Re: (Day Walker)
Im using though i dont have numbers to give ya they been great...Howard from ARfabrication tuned a gsr w/ eagles to 700+hp , I think they just take a bad rap
Old Nov 24, 2003 | 05:16 PM
Cyber ITR's Avatar
Default Re: (2ltrsnailpwr)
thats probably the one with the upgraded custom age 625 rod bolts
Old Nov 24, 2003 | 05:28 PM
TurboJesse
Guest
Posts: n/a
Even started with no oil. A guy from eagle posted one time on here that out of 900 rods sold last year, only 4 failures. And that was due to over or under tightening. Sometimes the internet can blow things out of proportion. </TD></TR></TABLE>
Really? i thought it was just the honda-tech extremist's that blew things outa proportion? Eagles going in my Mota
Old Nov 24, 2003 | 05:37 PM
Pfieff's Avatar
I got eagle rods going in my d16 over the winter, only looking for 300whp now, but you can't beat eagle for the price
Old Nov 24, 2003 | 06:05 PM
Boostage's Avatar
Default Re: (Pfieffdog)
https://honda-tech.com/zero...age=5
