B-Series Throttle Body on a D-serries intake manifold, will it work ?
Old Nov 22, 2003 | 08:43 PM
Vera's Avatar
Default B-Series Throttle Body on a D-serries intake manifold, will it work ?
i was wondering if a b series throttle body would go on perfect (except for the bore) on a d series intake manifold ... i searched around on here .. and found some that said it would .. and some that said it wouldnt work ...
so ...just wondering if anyone can clear this up for me ...
i can get a throttle body from a b18a ... but want to make sure it will bolt on with no hassle ...except for the bore matching of the intake manifold ...
thanx !!!
CRX 89 Si
Old Nov 22, 2003 | 08:57 PM
89civicdx's Avatar
Default Re: B-Series Throttle Body on a D-serries intake manifold, will it work ? (Vera)
no the holes don't line up with the a6 88-91 intake manifolds.
but if you swap over the z6 manifold the b tb's will fit on.
I was the one who posted how to make the b tb fit on a a6 mani...you have to drill the holes, its a bit of work but it can be done....but it is a "hassle"
Old Nov 22, 2003 | 09:17 PM
Vera's Avatar
Default Re: B-Series Throttle Body on a D-serries intake manifold, will it work ? (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">no the holes don't line up with the a6 88-91 intake manifolds.
I was the one who posted how to make the b tb fit on a a6 mani...you have to drill the holes, its a bit of work but it can be done....but it is a "hassle"</TD></TR></TABLE>
ah ok koo .. thanx for the info ... i believe i do have a z6 manifold , not exactly sure ... some parts i had bought off a friend of mine .. most of it came from a 95 civic ... but not sure on the IM ...
anyway to get a IM from a b18a to work on a d16z6 head ?
heh ... cause i can get the whole thing if i need to .. just didnt think about it ... would think it would be too wide or something ...
thanx !!
ProjetEF
Jan 25, 2008 05:15 AM
EJ8 GSR-T
Dec 19, 2005 07:53 PM
CRX_Phantom1
Oct 6, 2005 02:49 PM
Duck Sauce
Nov 28, 2001 08:47 AM
