window wiper removal...
Old Nov 22, 2003 | 07:45 PM
sExy_TinKY's Avatar
Default window wiper removal...
how do i remove the front and back window wipers from my 95 teg? i took off the black nut on my driver side wiper but the wiper arm still wouldnt come off...is there somethin else i need to unscrew? oh yeah...i wanna take them off so i can first take off and change the wiper blades and i wanna spray my wiper arms cause they've faded.
Old Nov 22, 2003 | 09:33 PM
IN VTEC's Avatar
Default Re: window wiper removal... (sExy_TinKY)
Flip the arms up, then pull them out of the armature.
The rear I think requires more fuss than the two front ones.
What kind of paint are you gonna use? I use the high-temp BBQ flat black stuff from the rattle can section in Wal-mart.
Old Nov 22, 2003 | 09:41 PM
ITR#JohnBasedow's Avatar
Default Re: window wiper removal... (IN VTEC)
for the rear, just pop off the black cap, and unscrew it. It's a tad more difficult than the fronts. While you're at it, just remove the whole rear wiper and motor
Old Nov 22, 2003 | 10:17 PM
FlaN.'s Avatar
Default Re: window wiper removal... (ITR0863)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0863 &raquo;</TD></TR><TR><TD CLASS="quote">for the rear, just pop off the black cap, and unscrew it. It's a tad more difficult than the fronts. While you're at it, just remove the whole rear wiper and motor </TD></TR></TABLE>
Old Nov 23, 2003 | 05:49 PM
purplevtec's Avatar
once you take the nuts off of the wiper arm tilt them up like when you are washing the car. then grab them at the base of the arm and yank up and down while also trying to twist a little at the base. Also you can squirt a little penetrating oil on the stud coming through the wiper arem, but don't get it on the windshield. you don't have to yank like a madman just be patient and they should pop right off. If you can slide something like a screwdriver under the base and gently pry up while you pull and wiggle they will come off. be care full not to scratch the cowl or hit the windshield. put a rag or something around the screwdriver so you don't damage anything. hope this helps.
2ndGenREX
May 4, 2005 05:26 AM
dip-set
Nov 8, 2004 10:30 AM
integraboi1010
Oct 26, 2004 10:36 PM
