APEXi N1 Question
Old Nov 22, 2003 | 04:43 PM
SubTitle's Avatar
Default APEXi N1 Question
Would a APEXi N1 axleback bolt right up to the OEM b-pipe?
Old Nov 22, 2003 | 07:51 PM
n0 iNTegRiTY's Avatar
Default Re: APEXi N1 Question (SubTitle)
I believe so.
I just replaced my cat-back. (N1 ). I did not notice if it fits flush, because I didn't need to unbolt that part, but I'm assuming it would, because the 2.5 fits flush with the cat.
Old Nov 22, 2003 | 08:15 PM
-1TSXer-'s Avatar
no, the stock b-pipe has a flange similar to the one on the header. The N1 axle back is flush.
Old Nov 22, 2003 | 08:31 PM
hYpE-R-29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SubTitle &raquo;</TD></TR><TR><TD CLASS="quote">Would a APEXi N1 axleback bolt right up to the OEM b-pipe?</TD></TR></TABLE>
yes it should
Old Nov 22, 2003 | 09:43 PM
SubTitle's Avatar
Default Re: APEXi N1 Question (hYpE-R-29)
so does it or no?
Old Nov 23, 2003 | 08:47 AM
SubTitle's Avatar
Old Nov 23, 2003 | 08:50 AM
skunkintegra's Avatar
well... is the flange on the N1 flush/flat?
if so, then no...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -CivicTuner- &raquo;</TD></TR><TR><TD CLASS="quote">no, the stock b-pipe has a flange similar to the one on the header. The N1 axle back is flush. </TD></TR></TABLE>
Old Nov 23, 2003 | 12:10 PM
SubTitle's Avatar
Default Re: APEXi N1 Question (skunkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">well... is the flange on the N1 flush/flat?
dont know
Old Nov 23, 2003 | 12:42 PM
dont know</TD></TR></TABLE>
ah.. ic... i thought maybe you had the axleback in your possesion.
well.. if its like most aftermarket exhausts.. its probably flat like this...
edit - i searched and found pix of the N1 system.. yes.. the flanges are flat... <FONT SIZE="2"> it is NOT a direct bolt on! </FONT>
just like civictuner said cheers
you'd need to mount it to this...
i suppose you could cut that 'flange' off
Old Nov 30, 2003 | 09:52 PM
SubTitle's Avatar
so what would have to be done to make it bolt on?
Old Dec 1, 2003 | 12:03 AM
DA9RsIntegra's Avatar
i suppose you could cut that 'flange' off </TD></TR></TABLE>
Old Dec 3, 2003 | 09:14 PM
filtereds0ul's Avatar
i had a 5zigen axleback and it fit the oem b-pipe just fine.
Old Dec 21, 2003 | 12:33 PM
SubTitle's Avatar
Default Re: (filtereds0ul)
so i would have to cut off the flange and get one at a muffler shop welded that would bolt up to my stock b-pipe?
Old Dec 21, 2003 | 01:07 PM
Alexander's Avatar
Default Re: APEXi N1 Question (DA9RsIntegra)
No need to cut the "flange" off, it comes off by itself (its a seperate piece)
I believe its referred to as a donut gasket? juts pull on it with some strong pliers, shold work its way off
Old Dec 21, 2003 | 05:32 PM
SubTitle's Avatar
Default Re: APEXi N1 Question (Alexander)
cool thanx, anyone have a APEXi axleback for sale
integra racr04
Jul 12, 2006 07:17 PM
skynyrd006
Jun 10, 2006 06:12 AM
HatchEh2
10
Oct 4, 2004 09:52 AM
Matt Groove
Oct 10, 2002 04:39 PM
iNteKra
Jul 28, 2001 11:14 PM
